Question about Hobart Handler 140 Mig Welder
HOBART HANDLER 135 GAS WILL NOT SHUT OFF
I HAVE REPLACED THE GAS VALVE AND IT STILL WILL NOT SHUT OFF. YOU CAN TURN THE GAS ON AND SOON AS YOU PLUG WELDER IN GAS STARTS COMING OUT AND WILL NOT STOP. IT ACTS AS IF IT HAS A SHORT IN IT. WHEN YOU PLUG IT IN IT CLICKS LOUDLY AND MAKES A LOUD BUZZING NOISE.
  • alcoholicarr Jan 17, 2009
    same problem as stated. i can sometimes stop this condition by turning the wire feed to 60-65 and the amp switch to 4, then getting a piece of scrap steel i start running 2-10 hot beads until the condition stops. once i don't hear gas hissing out of the tip i shut the gas off and then the welder. i let the welder sit for 5-10 minutes and usually it's good to go. i don't know why it does this. i can only guess it's a relay or solenoid that gets stuck on. i too have a hobart handler 135. it's a great welder except for this problem.
  • David Shaub May 11, 2010
    There is a solenoid that controls the gas flow. If it's stuck, you will get gas flow. It will also stick if it gets frosted up too much. If it does, turn your gas back.
    Problem Solver:
  • 14 Answers
Relce the gsi unit to regulate the gas flow.hope this helps jojgunn
Posted on Mar 15, 2009
  • 92 Answers
It doesn't take much to jamb the solinoid , too much presure on the argon will hold this open, turn the gas off, purge the line, release the pressure on the regulator, Now turn the gas on and put approximatley 2-3lbs only on the gauge, turn the flow meter for a reading of 15-20ltr/min, then try again,
Posted on Jan 23, 2009
Hobart handler 135, the wire starts to feed for about 15 seconds then slows and stops.
Hi:
Don't know how old is your unit but my guess is that your gun's liner is the problem. Have you change it lately? If not, change it. Does your machine just stops feeding the wire or does it shuts down? If it just stop then; is the liner, if it shuts down; then you have a pc board problem.
Oct 29, 2011 | Hobart Handler 140 Mig Welder
I have a hobart 135 handler that with machine plugged in and turned on the wire has constant juice and the gas cylonoid is flowing gas from the bottle without the trigger being pressed. my dealer said it...
Hi:
Have you disconnect the gun's power plug? If the wire and gas stop flowing by doing this action, then your problem is the gun's trigger. If the machine continues to feed gas and wire with the gun disconnected then yes, it is the pc board.
Good luck.
Aug 25, 2011 | Hobart Welding Tools
I have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Jan 05, 2010 | Hobart Handler 140 Mig Welder
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
I have a hobart 135 welder that is not working right. The gas keeps running when your not welding. When you plug it in it sounds like something is running inside without it being turned on. Do you know...
This sounds like the gas solinoid, first, check the gas flow, this should be 12 - 15 ltr per min: if thegas flow is to high it will hold the solinoid vale open. you can reduce the gas flow to a minimum, then check to see if the solinoid closes and opens, if not the iether the voltage to the solinoid is too low or the solinoid plunger is damage, replase the solinoid. lets know .
Nov 17, 2009 | Hobart Handler 140 Mig Welder
Hobart Handler 135 not feeding wire
try checking your heat selector switch. the pc board gets power from it. so the pc board relay may function (click) but have little or no power once the curcuit is made to the feed motor. it happened on my 135.
Jul 29, 2009 | Hobart Handler 140 Mig Welder
Seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
Dec 23, 2008 | Hobart Handler 140 Mig Welder
Hobart Handler 140 Mig Welder Logo
845 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Delage guy
Delage guy
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
