The monitor turns on during the course of operation it makes a popping sound and then it turns off,
    President:
  • 2,692 Answers
Try substituting another monitor just to see if it ias the monitor or something else.
Posted on Dec 15, 2008
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
Menu screen keeps popping on and off during usage
Check the menu button on your monitor. Chances are it is stuck in the depressed position. (Sometimes an edge of the button will get caught beneath the frame.)
Jun 01, 2009 | Dell E157FP Monitor
No picture and make popping sound hp w2207.
Popping sounds from electronic devices is never a good sign. It generally means that something was shorted out inside the item. You will need to bring it to a qualified technican for repair or buy a new monitor.
Apr 12, 2009 | HP w2207 Monitor
LiquidVideo monitor will not come on at bootup.
Blown capacitors internal to the monitor they can be replaced by soldering.
let me know what you want to do
Mar 22, 2009 | Computers & Internet
Etronix Flat Screen Monitor PROBLEM!
what video card and what monitor are you using????
what operating system???
what make of PC??
need more information.
Oct 22, 2008 | Computers & Internet
Hp F 2105 MONITOR
I know about that volume pop up that refuses to go away. I figured out that it goes away if I press the "Menu" button. If that doesn't work, I have no idea what will.
Mar 20, 2008 | HP f2105 21" LCD Monitor
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Pop goes the weasel...
Chances are a capacitor has blown. They normally make such lovely poping noises when they die.
What will of course now be happening is the voltage inside where that capacitor was will be unstable and it could very well completely fail in the near future.
I would reccomend you get it to a repair shop sooner rather then later for a cheap simple repair rather then an expensive monitor replacement.
Dec 14, 2007 | Dell UltraSharp 1905FP LCD Monitor
IBM 21" frequent tick sound!
too much refresh rate! set it to 60 hz only! you're over-stressing major components on your monitor!
Dec 02, 2007 | IBM P 202 21" CRT Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
