Error code 126 which is wxfw.dll. file try to uninstall desktop can't find thur tech.support was given web address when type in says changed or not available
  • PURE_POLO Jan 11, 2009
    I want to install WindowsXP sp2 and samsung ML-1610 at installing Msg box show "Smart UI 32-bits Gateway error " (Can't load SMART Utility Library (Code 126) The specified module could not be found)
    Please ! Who fix problem please contact PUREPOLO@Gmail.com
    President:
  • 2,692 Answers
Error Code 126 is a critical Windows error and is caused by a corrupt registry entry that should be repaired immediately to prevent further corruption in other applications and/or hardware. Risks include hardware failure, blue screen errors and fatal crashes.  I would reinstall windows if you don't have a backup registry disk. I would also look at my last download or new hardware install at the likly problem that coused the code.
Posted on Dec 15, 2008
My slcdii file is missing, how do I retrieve it?
Its scl dll file not slc dii.
1. Download, install and run DLLSuite,
2. Click Start Scan button to conduct a full scan for slc.dll as well as corresponding issues
3. Locate to file slc.dll and click More Information. You will reach a web page where you can download slc.dll file.
Tips: Before save slc.dll to its path, please use DLLSuite to create system restore points first as if the file path is incorrect, your system would become unstable, even crash.
4. Click Start, Run and type regsvr32 slc.dll , and then press Enter.
5. Restart your computer
Hope it works for you.
Also use a sytem utility software like ReginOut to avoid such type of errors. It will optimize your PC and fix different operating system errors.
Dec 26, 2011 | E-Machines (T3104) PC Desktop
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d9.dll/
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Whenever we try to open skype a dialoge box apppears showing fatal error failed to load library d3d9.dll.
You will have to re-install the Skype application in order to get rid off the error.
Please follow the below step:
1. download and install the Revo uninstaller application online(It's free).
2. Look for the "Skype" application and select the "uninstall" option.
3. Select "Advance" scan and remove all the remaining files of skype.
4. Reboot the computer.
5. download the d3d9.dll file from the following website http://www.dll-files.com/pop.php?dll=d3d9
6. Copy the d3d9.dll file and paste it at the following location C:\windows\system32
7. You will have to register the dll file before installing the skype application. To register the dll file:
Click on "Start" menu and select the "Run" option or Simply Windows key+R
Then, type regsvr32 d3d9.dll and click 'OK" .
8. Once the dll file is registered, you can install the Skype application and continue using it.
I hope this should fix the issue.
Thanks, Vicky
Dec 27, 2010 | Compaq Presario 5000 PC Desktop
Following message appears when I try and play game: Couldn't load language resource dll Error filr Error code 0x7E (126) Any ideas??
uninstall the program and reinstall, if prompted to over write select yes. if that doesnt help it, go to this site and run a scan after you uninstall the program and after the scan reinstall
Oct 24, 2009 | Microsoft Flight Simulator X for Windows
Error messages
Uninstall the Windows defender and install am updated version. If it doesn't work, try this:
To resolve this problem, follow these steps:
1. Uninstall Windows Defender, and then reinstall Windows Defender. To do this, follow these steps:
1. Click Start, click Run, type appwiz.cpl, and then click OK.
2. Click Windows Defender, and then click Remove.
3. Follow the prompts to uninstall Windows Defender.
4. To reinstall Windows Defender, visit the following Microsoft Web site:
http://www.microsoft.com/athome/secu...yware/software (http://www.microsoft.com/athome/secu...yware/software)
2. If this issue is not resolved after you complete step 1, uninstall Windows Defender, use the Windows Installer CleanUp utility, and then reinstall Windows Defender. To do this, follow these steps:
4. To use the Windows Installer CleanUp utility, click the following article number to view the article in the Microsoft Knowledge Base:
290301 (http://support.microsoft.com/kb/290301/ ) Description of the Windows Installer CleanUp utility
5. To reinstall Windows Defender, visit the following Microsoft Web site:
3. If this issue is not resolved after you complete step 2, follow this step:
1. Click Start, click Run, type regsvr32 file name, and then click OK.
Note In this step, file name is a placeholder for the following files.
Repeat this procedure for the following files:
* wuapi.dll
* wuaueng.dll
* wucltui.dll
* wups.dll
* wuweb.dll
* atl.dll
* softpub.dll
* wintrust.dll
* initpki.dll
* mssip32.dll"
cheers ...
Apr 10, 2009 | HP Pavilion 520c PC Desktop
When opening canon zoombrowser the error msg. below is shown.
msvcr80.dll is a Microsoft Visual C Runtime file. Try to eliminate the .dll file first as being the culprit. Type in "download msvcr80.dll" in any search engine, download it, save it to your desktop. Using windows search, locate msvcr80.dll on your system, (usually in c:\windows\system32) and rename it to msvcr.dll.old, then copy the newer file to the same location as the oler one, the reinstall your suspect program, reboot, then try to run the program again.
Apr 01, 2009 | Computers & Internet
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Msls31.dll file missing
OK,
U can Find & Download This DLL File form Following Web Link......
http://www.dlldump.com/dllfiles/M/msls31.dll
After Download this file follow the blow steps-
1- Copy & Paste this File in "C:\windows\system32"
2- On Desktop Click on "Start" & Click on "Run"
3- When Run window appear, type the following command
       regsvr32 msls31.dll
NOTE: Give a Space Between regsver32 & msls31.dll
4- After type the command hit ok, a popou window appear again hit ok
That Done Now Ur EZ Soft should Run Properly....
If after this any problem persist, send me the error (as given by window). I will happy to help U.
Tip:- U Use XP Home Edition, It is Good But I Suggest U that U should Use XP Professional SP2 Edition it is Better & Having more Softwere Competibility.
Nov 08, 2008 | Microsoft Windows XP Home Edition
Install missing dll file
Dear
If u have missing .dll file (download from web)
copy .dll file to c:\windows\system32
go to run and type (if ur dll file is abc.dll)
regsvr32 abc.dll
and press enter n ok
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
1,636 people viewed this question
David Payne
David Payne
