Question about Dryers
Replaced dryer belt dryer was heating now isn't
Replaced the dryer belt on a GE Spacemaker Model GDM1380S was working (heating) for a while now does not heat at all
    Problem Solver:
  • 4 Answers
There could be 2 problems coming into play here.
1. Check to make sure there is no blockage in the vent piping. If the vent is blocked and the air cannot discharge from the dryer, the heating element will overheat and the overtemp thermostat will turn the heating element off.  (By the way, Blocked vent is usually the No. 1 Culprit in problems like this.)
2. Check the heating element and make sure that the heating coils are all intact. An open or shorted heating coil will cause the same symptom.
Posted on Dec 15, 2008
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
GE SPACEMAKER dryer working but blowing cool air. what do i do?
check for proper voltage to the machine should have 220 volts if you only have 110 volts it will run but not heat if you have 220 volts you could have a bad heating element
Nov 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE spacemaker dryer heats up but will not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2010 | GE Dryers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
My GE Spacemaker Dryer Model WSM 2700 DA no longer heats up. HOw difficult is it to change the heater element or is that the problem? P.S. I have cleaned all the vents out with very little material found.
either the heating element, hi-limit switch, thermal fuse (on some), cycling switch,or a burned neutral power wire in the unit, first, make sure you have 240 volts input power
Oct 22, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
ryur
Sep 17, 2009 | GE Spacemaker Washer and Dryer Electric...
Can you convert a 220 dryer element to a 120 ellement
no that machine is wired for a 220v. has 220v components in it. no way to change that sorry
Feb 23, 2009 | GE Spacemaker Washer and Dryer Electric...
Smells like belts are burning during rinse cycle while washing
TAKE OFF THE FRONT PANEL BY TAKING OUT THE TWO SCREWS AT THE BOTTOM. SLIDE THE PANEL DOWN ABOUT HALF AN INCH AND THEN PULL OUT. YOU CAN NOW SEE THE INNER WORKINGS. AS FOR PARTS, TRY WWW.MARCONE.COM
Jan 07, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
127 people viewed this question
Top Dryers Experts
