Question about Dymo LabelWriter 400 Thermal Printer
Printing labels and it jammed. pulled nose to get out label.
When nose was pulled off a thin cloudy plastic guide fell out. We don't know how it goes back in?
If you r trying to print from word , changet the papet type in the printer . this will solve the problem
Posted on Dec 14, 2008
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
Jammed with gummed stickers
Always put stickers in the shredder between two layers of 3-4 plain paper sheets. That's for future.
Now I would suggest getting some "Label Off", "Label Killer" or similar spray product, that will dissolve the glue, spraying the cutters and stuck labels with it several times, trying to remove them with tweezers or thin long-nose pliers. Be gentle, try not to blunt the cutters' edges.
When you get rid of the labels, spray more of the stuff on the cutters and clean them with a brush, to remove glue residue between them. Do it several times, rotating the cutters to remove the glue all around.
Then lubricate the cutters as per manufacturer's recommendations.
Nov 14, 2009 | OfficeMax 0M96431 Shredder
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Jun 12, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
Lexmark C782n uesd for vinyl labels keeps jamming
Please follow this link to the Users Guide for your printer then go to the Labels section.
http://www.lexmark.com/publications/pdfs/2007/780/ug_en.pdf
Don
May 12, 2009 | Lexmark C782N Laser Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Paper jam in hp deskjet 5900 series. how do i correct?
 Follow these steps to remove a paper jam:
1. Press the Resume button.
  If the paper jam does not clear, then go to the next step.
2. Turn off the printer.
3. Remove the rear access door. Press the handle to the right, and then pull out the door.
4. Remove any paper that is inside the printer by pulling it out from the back of the printer.
  If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
5. Replace the rear access door securely.
6. If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover. Caution Remove the paper jam carefully as it is possible to damage the
  printer when removing paper from the front.
7. Turn on the printer, and then press the Resume button.
8. Reprint the document. Note If paper jams occur frequently, try using a heavier paper. See the reference guide for paper weight specifications.
Jan 29, 2009 | Office Equipment & Supplies
Plastic labels jammed inside of printer.
they are stuck in the fuser unit, try to take out the toner cartridge to see if you can get it from their. if not you may have to call for service help. you have to take the back of the machine apart and take out the fuser unit to get out the lables. sorry that i didnt have better help.
Nov 02, 2007 | Brother HL 1440 Laser Printer
Letra Tag QX50 Error 1 message
Don`t close the back plane compleet, push print and pull on the tape, now it runs on mine. Close the back plane and everything is ok now, Good Luck!
Michel
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
Dymo LabelWriter 400 Thermal Printer Logo
65 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
