Question about Dual XD-7500 CD Player
Flip Down faceplate is stuck.
I Have had this cd player in my car for over a year now and had no problem with it until now. It happened all of a sudden, I had no warning or prior acting up at all. When I turned on my car the moving faceplate was in the closed position and when I hit the Open button to open the mannel to view the time and everything else on the display it won't open, nothing happens when I hit the eject button either. The cd doesn't stop playing or anything when i hit eject. I messed around with the moving faceplate and pulled it into the open position so that I could at lest view the display, but the open and eject button still doesn't move the panel and will not eject the cd. Your help or knowledge of who can fix these things will be greatly appresiated. Thanks
  • 3 more comments
  • Anonymous May 13, 2008
    this stereo is ****! i cant believe i payed all that for this. mine is stuck also. and im not sure how to get the face plate off there.
  • x_tremehonda Jul 27, 2008
    my open button and eject does not work either all of a sudden, it has not been damaged at all
  • Anonymous Jul 31, 2008
    I also have the same problem, the other morning i turned my car on and pressed the open button and nothing happened. I tried reseting it also and that did not work.
  • 13B20 Aug 26, 2008
    I had this same problem, and all I did to fix it is push one of the small gears in the bottom corner back in place. hope it works for you too.
  • Anonymous Aug 30, 2008
    Same problem as stated here
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Posted on Aug 26, 2008
I dont know how to get the face plate off?
Posted on May 13, 2008
I have same problem and think it may be a weak moter but if you open the top of your stereo which is easy on these with front of it facing you there is a wheel to the front right side you can rotate to open face plate then turn it back on it with it open should work for a few days I live in A.Z so it may be a heat problem to do to it seems to screw up more during summer I will never buy Dual again
Posted on Oct 05, 2007
    Problem Solver:
  • 14 Answers
Like duncan say the problem is the flat connector between the flaceplate and the chasis stereo....in sonys stereos it happens,faindem for the model of your stereo in mexico =sonora i purchase in 18 bucks more or less.
Posted on Mar 22, 2007
    Novelist:
    Champion:
  • 218 Answers
You may have a broken lead in the ribbon cable that goes between the flip face and the main circuit board. If you do, then you will of course need to replace that flat ribbon cable. A broken lead in the ribbon cable is a very common problem in car radios with a flip face.
Posted on Mar 16, 2007
  • 156 Answers
Unfortunately this is a common failure in these radios. You can try pressing the small, recessed "reset" button on the front face, but odds are that it won't fix it. It's quick and costs nothing, however, so it's worth a try.
Why would my '02 Olds Alero suddenly not shift into reverse?
My guess is the ignition needs to be replaced. check to see if theres a recall for it. 2 years ago on my 2002 alero I found a recall for the flasher switch which was causing intermediate directionals and 2 more for the computer
Jun 30, 2014 | 2002 Oldsmobile Alero
Why would my 2002 Olds Alero suddenly not shift into reverse?
Does it have a vaccuum modulator for transmission?
Oct 30, 2017 | 2004 Mercury Grand Marquis
CD player displays error code: ER-1
The ER-1 code signifies an unknown error. Try cleaning the player itself, as well as cleaning the individual CD's prior to inserting them.
If that doesn't remedy the issue, ask for further help.
Feb 02, 2014 | Dual Electronics XD1222 Car USB Player
Hi. I recently bought a Sony CDP-CX355. Until a few days ago it was working fine. Suddenly, the player stopped reading the discs. It grabs a disc as if its going to play it, but just reads it, and then...
This happens when your laser is not able to read the data of the disc. Either u are using disc which the player cannot read or the disc is not readable. If your CD player is not reading the discs which it used to read earlier then CD player laser head has to be replaced.
Aug 14, 2010 | Sony Audio Players & Recorders
Can i download ARCSOFT photo impression4.0?
That's probably your only choice until you get a CD drive.
Jan 27, 2010 | Cameras
Sony CDX-GT210 CD Player not working all of a sudden
remove the unit and the reset button should be a small pin hole on the back!
hope this helps
alex
Apr 06, 2009 | Sony CDX-GT210 CD Player
Pioneer P80MP, dont power up but ejects
You should start by taking the radio out of you dash. Check to make sure that the Red wire, Yellow wire and Black wire are all connected properly and that wire is not exposed. It could be grounding out. Or, sometimes there are multiple fuses for you radio. In my car there are 4 in the fuse panel.
Jul 31, 2008 | Pioneer DEH-P80MP CD Player
I cannot produce a finalized music cd able to be hear on regular cd player
the .wav file has to be converted to .mp3 or .cda prior to burning in order to hear it in a regular cd player. Those applications have the ability to turn .mp3, and .wma to .cda format, which is what normal cd players read but they lack the ability to convert .wav to .cda
Mar 01, 2008 | TDK DED+840 DVD±RW Burner
JVC KD-LH300
dirty,clean the optical pick-up?
Apr 30, 2007 | JVC Sirius KD-LH300 CD Player
Dual XD-7500 CD Player Logo
1,049 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
