Question about Mitsubishi WS-55807 TV
I need the V-Chip code for an HD 1080 series TV.
My father-in-law passed away and I now have his HD 1080 Mitsubishi TV. The V-chip islocked and blocks many stations and i don't know the code. Is there a factory setting or an overide code I can use?
  • Anonymous Jan 19, 2009
    all of a sudden, my t.v. has a big black block on the screen. Far as I know, no one put a block on the tv. I don't know how to get the block off. My husband is messing around with codes... if we hit the mute button on the direct tv button, the screen is restored for about 1/2 a minute...then the black block is back on again...help
  • llanzendorfe Apr 14, 2009
    I have the same problem. For the last 2 years we pressed the QV and 9 buttons and it would unlock. Well now that is not working and I'm back to square 1. Any tips???
Delete characters by pressing cancel for each character
Posted on Dec 15, 2008
  • norcalsailor Dec 15, 2008
    view the locked tv without entering your passcode. this is done by pressing the number 9 and QV buttons on the remote TV control at the same time, when your passcode is requested, this process temporarily unlocks the TV, When entering the V-chip lock minu, this process deletes your old passcode and propts you to enter a now one
  • Anetra Marie
    Anetra Marie Jan 07, 2014
    It worked for me:: :)
    New Friend:
Thank you .
Posted on Nov 23, 2013
My 55 inch Mitsubishi hd 1080 has white spots on screen
it is dmd chip issue. dirty or goes bad.
firstly, try to clean DMD chip, if no helpful, you have to replace it by a new one.
good luck for you
Aug 23, 2014 | Televison & Video
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
The v chip locks up how do we remove this if dont have code for good on hd 1080 is there a code change to remove the original
SETTING V-CHIP
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
NOTES:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Hope this helps.
Jan 21, 2010 | Mitsubishi WS-55807 TV
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Unlock parental control
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Apr 01, 2009 | Quasar SP-2722 27" TV
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
I hope that helps.
Feb 18, 2009 | Mitsubishi WS-65515 65" TV
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi 1080 hd
check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-soldering doesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
Feb 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55807 TV Logo
837 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
