Question about Maytag UXT5230AD Kitchen Hood
Maytag UXT5230AD Kitchen Hood - Right Hand Light Cycles On and Off
I purchased my range hood a little over 1 year ago. In the last 2 weeks the right hand side light has started to cycle on and off during use. Typically it stays on for 3-4 minutes, turns off for 3-4 minutes and repeats the cycle. The left hand side light does not cycle and is always lit when powered. I've replaced the bulb and get the same result.
    President:
  • 1,462 Answers
Probaby just the bulb holder
Posted on Mar 20, 2007
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Jul 29, 2013 | Kitchen Ranges
HV363 Kitchen Hood
either the button is sticking or the switch needs to be replaced.remove all power and try again.
Oct 25, 2007 | Jenn-Air HV363 Kitchen Hood
Problem with cooker hood
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Mar 09, 2010 | Rangemaster Kitchen Hood
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
How to Install as Ductless
it should mount sqaurely to the bottom of the cabinets over the stove/oven
you will need a 120v power supply
but it is pretty straight forward other wise
Apr 02, 2008 | Maytag UXT5230AD Kitchen Hood
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
Dec 30, 2007 | Kitchen Ranges
Oven does not heat
Gowen, more than likley it's your ignitor that failed. Remove the ovens bottom panel by removing the 2 screws in back and lifting up. Remove the nut from the flame spreader and you will see the ignitor. Now turn the oven on and look at the ignitor, does it glow. Even if it does, it needs to draw at least 3.2 amps to open the gas valve. Part number for the ignitor is 5303935066. Easy job. Catriver...post back.
Nov 05, 2006 | Frigidaire FGF316 Gas Kitchen Range
Maytag UXT5230AD Kitchen Hood Logo
298 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
