Question about Maytag Performa PAV2200
Dryer leaving black marks on clothes
We think that the drum is rubbing on something the drum seems to be loose and the thing that holds the drum in place is broken the dryer is a performa pye/g2000 not sure what the part is called to find a new one
    Genius:
  • 1,061 Answers
Contact the factory for replacement patrs.richardm69
Posted on Dec 14, 2008
My crosley dryer is making a terrible scraping noise. I lifted the top of the cover off and could see the drum. There are several scrape marks in a few spots. Obviously it is rubbing on the bottom. What is...
The first thing to check is whether there is something caught in the drum rim (both front and back). Feel around the circumference of the drum in both places for a piece of clothing or pocket item jammed in there. If all is clear, then most dryers have drum glides on the front that will wear. Those aren't expensive and not that hard to replace for the mechanically inclined. A bad rear support roller is also a possibility. To replace it , the drum will probably have to be removed. Drums aren't that hard to get in and out, depending again on your mechanical ability. Hope that helps
Jan 02, 2010 | Crosley Dryers
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Frigidaire Dryer. Clothes are damaged by either being ripped when caught on dryer drum. Clothes also are marked with hard to remove rub marks.
Open the dryer door. Reach in just inside and feel for the felt seal that goes all of the way around the drum. The culprit is usually the top portion of the seal which supports the end of the drum near the door is worn out. This allows the drum to tip down and leaves a gap at the bottom. Clothes get caught in this gap and get rubbed and marked or rubbed clear through. Remove the front of the dryer and replace the seal. On some models the top 1/3 is replaceable. This portion carries the weight of the drum and is what wears out.
Jun 06, 2009 | Frigidaire FEQ1442ES Electric Dryer
My neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Hello
Welcome to Fixya
My name is Huum,
You said, my Neptune dryer sounds like screws are tumbling, one of the 3 dividers connected to the drum inside the dryer is loose and it is leaving black marks on clothes
Those are the screws that hold the dividers to the drum.
The drum ha to come off to replace them. Big job!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
GE dryer, black grease stain on cloth
I have the same problem, I haven't resolved it but it seems to be due to the drum of the dryer being able to move more than it's supposed to and things getting caught in between the drum and whatever it sits in, at the front of the dryer. I have found things caught in there before and when I've pulled them out they had a brown/yellow grease stain on them. Other times something in the dryer will have this same stain - although no longer caught it seems it must have been caught at some point then became free again, with the stain. I'm thinking something is loose or if the drum is supported at the back by a bearing of some sort, this bearing may be worn down and the drum isn't sitting right.
Dec 19, 2007 | Dryers
Washing Machines Logo
318 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
