Question about Miele 24 in. G881SCI Built-in Dishwasher
Miele NOVOSTELLA PLUS Dishwasher Drain Light is on. The dishawasher does not drain properly. I removed the pieces and cleaned them.
My Miele dishwasher has the red drain light on and won't drain
most common, debris stuck in the drain pump. remove the triple filter, remove the non return valve. clear the debris from the drain pump impeller. try to drain again. also make sure you dont have an obstruction in the drain line. if you replaced your garbage disposal recently, make sure they knocked out the drain plug when they connected the dishwasher. also make sure your dishwasher drain line connects directly to the disposal, and does not run to a air gap in your countertop. miele dishwashers will not function properly when connected to an air gap.
Mar 23, 2012 | Miele Dishwashers
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
We've got an Meile Incognito dishwasher, model G 843 SCVi plus. It purges at the begining of the cycle and then seems to fill with water, but then the red Intake/Drain light starts to flash and the cycle...
I would start by checking the drain line where it is connected to the garbage disposal. Check and make sure there is no solid build up obstructing the discharge into the garbage disposal. You can go a step further by removing the dishwasher drain line for thorough check up
If it has been establish that there is no obstruction by other means. There may be a problem with the control board.
I would suggest cautious approach in making rush decision on replacing the board.
Here is a link to the manual
Aug 02, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. it...
the unit will not fill with water until it will drain as it needs to complete the drain function before it can move onto the next step.
make sure the non return valve under the filter is properly fitted in the sump of the unit. then check the drain spigot under the sink where the drain hose connects to the sink u bend. This is the most common causes of a blocked drain.
Nov 28, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Dishwasher stops after 10 minutes inlet/drain light flashing
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G646SC Plus dishwasher Drainage / inlet warning light
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Sep 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G881SCI Built-in Dishwasher Logo
81 people viewed this question
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
