Acer AcerScan 320U Flatbed Scanner
Problem for Acer AcerScan 320U Flatbed Scanner
Acer Scanner
By moselka on Dec 14, 2008
Hi
Thanks for your posting. I have installed the cd 'mirascan' which installs a TWAIN driver and relevant programs to run scanner. I plug in my scanner but my computer doesnt recognise the scanner. I have tried to add it manually through add hardware as well as adding it through scanners via control panel, but it keeps rolling back saying not enough storage space. the light is definately on in the scanner and plugged in via USB to laptop. I suspect it is because the driver for the scanner is not vista compliant, but the Acer web site has no downloads for this product.
Same Problem
Mar 29, 2009
-   Tengo exactamente el mismo problema que moselka -   amparo_pn
Mar 29, 2009
-   Tengo exactamente el mismo problema que moselka -   Guest
Jan 21, 2009
-   It seems that the scanner 320U Flatbed Scanner is not compatible with VISTA. My PC, with OS Windows Vista, does not recognize my scanner. So, since several months I'm looking for a driver that could resolve the problem.-   Guest
Solution #1
posted on Sep 10, 2009
Not Rated)
rjonna
Rank: Apprentice
Rating: 0%, 0 votes
Buenas Noches, tengo un problema instalo todo y cuando voy a sacanear me dice qe no tengo taiwan32.dll que hago por favor
Was this helpful?
Yes
No
Solution #2
posted on Dec 15, 2008
Not Rated)
scoobystones
Rank: Apprentice
Rating: 100%, 1 votes
well i can try to assist you.. its difficult to do it thru posts here if u can come online via chat.. it would be great
Was this helpful?
Yes
No
Popular Solutions for Acer AcerScan 320U Flatbed
Questions and Unsolved Problems for Acer AcerScan 320U Flatbed
Do you recommend Acer AcerScan 320U Flatbed Scanner?
Answer
Answer
Scanner will not do it's "warm up" pass. It goes part way, and then returns to start. I... (More)
Answer
scanned image is only 33% of the full veritcal image
Answer
Scanner will not do it's "warm up" pass. It goes part way, and then returns to start... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer AcerScan 320U Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
