Question about Pioneer AVIC-N1 Car DVD Player
Unit turns on when ignition is turned on and screen opens then nothing?
When I switch the ignition on the unit turns on and lights up,the screen opens then when the screen is open the unit shuts down.The lights go out and no screen,any help would be great.
  • 199 Answers
Hi sounds like it could be the flexi cable see: http://carradiospares.co.uk/avicx1rn2-flexi-repair-gxx1257-p-172.html
Regards
Mark
Posted on Feb 24, 2008
SOURCE:
Key turns ignition zwitch but nothing happens
Do the headlamps light ? Dome light come on when you open the door ? Did you check for bad fuse's that supply the ignition switch ? Check fuse's F422 - 20amp and F431 20 amp . These supply B+ voltage to ignition switch .
Jan 01, 2017 | Lincoln Cars & Trucks
1992 heritage softtail Turn ignition switch on and
Sounds like the electrical portion of the ignition switch. Check battery connections to switch first, if all tight, more than likely the switch is going out.
Oct 10, 2014 | Motorcycles
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Craftsman 917.276920 will not start. Turn key you hear a clik but will not turn over. Have replaced brake switch. Still nothing. Has a seat switch with 4 ends. Put meter on 2 end ones you get a beep. When...
It sounds like a normally closed switch, that grounds ignition out when you get up from the seat. When your sitting on the unit switch is open. If your familiar with a multimeter I would have some one on the seat and check power to the solenoid on battery side, turn key and check on opposite side, also small lead on solenoid to make sure power is getting to solenoid from ignition switch. This should help you narrow down the problem. Also, don't forget to test battery and check fuses. Good luck.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Oct 22, 2013 | Craftsman Garden
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
I was sitting at a stop light and the car died and smoke came from steering column ever thing else works light radio etc but when you turn the key there is nothing no idiot lights no miles nothing the car...
Maybe the ignition switch burned up. A lot of juice travels through them and it has happened.
What is confusing is, lights will work without the switch. You should be able to turn lights on without the key in the ignition. But a radio normally needs the ignition turned to ACC (accessory) or ON. And some when left on don't turn off with the key off until the door is opened.
Possibly the ignition melted and is affected to where the radio still gets power as if it was in the ACC position
Sep 08, 2011 | Ford Focus Cars & Trucks
My U line model 2015rs just quit working. Power
Thermostat is more than likely bad. Nothing runs but light is on
Sep 28, 2009 | U-Line 15R Compact Refrigerator
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pioneer AVIC-N1 Car DVD Player Logo
129 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
