Question about Toshiba Satellite A130-ST1311 Notebook
Can't reboot computer
I bought a used Tochiba satellite a130-st1311. the only thing that comes up on the screen is a request for a password. when I hit control alt del it reboots quickly. I don't know what to do
Enter bios password on a130-st1311 notebook
If you've forgot the password you can reset the BIOS password by following the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Apr 05, 2011 | Toshiba Satellite A130-ST1311 Notebook
My Toshiba a130-st1311 will not power on green power light comes on lcd for the accord is lit also the batt. lcd is 0n and power lcd is on but there nothing that come up on the screen ! can u help me!!
try another monitor on it. plug it in the VGA output port. if the monitor works, display comes then i think u have a problem with the laptop lcd panel, u need to replace it. or you can remove the memory from the slot and replace it back again, see if display comes. try these 3 solution
Aug 09, 2009 | Toshiba Satellite U305-S5097 Notebook
PASSWORD FOR BIOS OFR A SATELLITE A130/A135 SERIES
some set a password for you laptop.. you need to contact toshiba for this and prove ownership for the laptop.. or... you can try to open up your laptop and short the bios battery so it would reset..
Jul 09, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite a130/a135 series. I connect to
check the power cord to the laptop in the back wiggle it. check the lights. if they come on and go off with you giggling the power cord. the ac input socket may be broken. you may have to wedge it in one spot to get the two lights to come on let it sit there a while 20 min to charge battery some then turn on laptop.
Jun 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Wont power up
Ouch! Well it depends on a lot of factors, such as did the fluid make it all the way to the motherboard, how long ago it happened. If you are not getting any power at all, no fan, no lights, etc. then the motherboard is probably shorted out. The best thing you can do it take it to a pc repair shop and ask for an estimate only..don't let them fix anything right away. The cost of fixing it may not be worth it, versus just getting a new computer. Also lay your notebook on a towel with the lid open and on its side so it can dry out. Let me know if you have any questions. Pls rate this solution with 4 stars before logging off.
Mar 29, 2009 | Toshiba Satellite A130-ST1311 Notebook
My 4 usb ports of toshiba A130 donot recognize flash disks
Hi segidom
Sure let me try.........
I would request you to try with the following steps:
If u are using Windows XP as ur operating sysyem please perform with the folowing steps:
1.Right click on My Computers
2. click on Manage
3. click on Device manager
4. In the right side u find all options of the hardware components installed in ur notebook
5. Find for the option Universal serial Bus controllers
6. Find whether any yellow mark is there on that option or sub options of that menu especially on USB Root hubs.
7. Right click on the USB Root hub (all) present in that menu and click on disabe option and then wait for some time
8. After few minutes Right click on the USB Root hub (all) present in that menu and click on enable option and then wait for some time
9. Now Restart the note book and check
If u think that an yellow mark is present on any of the option then please right click on the particular option and click on update drivers and follow the steps as per mentioned in that particular window.
Feb 17, 2009 | Toshiba Satellite A135 Notebook
Toshiba A215 bios password
This is a known bug on some Toshiba lappies - and one of the reasons I updated my A215 BIOS 4 times in the last few months!
Not sure if this is what happened to you, but...
Applicable Models: Satellite A100-ST8211, A100-SP471, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4014, A105-S4051, A105-S4094, A105-S4144, A105-S4034, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4211, A105-S4201, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4104, A105-S4074, A105-S4547, A105-S4334, A105-S4304, A105-S4294, A105-S4364, A105-S4344, A105-S4021, A105-S4031, A105-S4012, A105-S4011, A105-S4397, A105-S4374, A105-S4384, A105-S4022, A110-ST1111, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S4499, A135-S4498, A135-S4488, A135-S4478, A135-S4507, A135-S4487, A135-S4477, A135-S4467, A135-S4457, A135-S2396, A135-S2386, A135-S4637, A135-S4527, A135-S2356, A135-S2346, A135-S2336, A135-S2376, A135-S2326, A135-S4517, A135-S2306, A135-S4727, A135-S4677, A135-S4666, A135-S4656, A135-S2426, A135-S4447, A135-S4437, A135-S4427, A135-S4417, A135-S4407, A135-S2296, A135-S2286, A135-S2276, A200-ST2041, A200-ST2042, A205-S4617, A205-S4639, A205-S4618, A205-S4567, A205-S4577, A205-S4587, A205-S4597, A205-S4629, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S7468, A205-S7466, A205-S7464, A205-S4607, A205-S4578, A205-S4557, A205-S4537, A205-S4638, L35-SP1011, L35-S2194, L35-S2174, L35-S2161, L35-S2316, L35-S2366, L35-S2206, L35-S2171, L35-S1054, L35-S2151, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST1071, P100-ST9612, P100-ST9412, P100-ST7211, P105-S921, P105-S6002, P105-S6014, P105-S6054, P105-S6034, P105-S9337, P105-S6227, P105-S6217, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6024, P105-S9312, P105-S6004, P105-S6012, P200-ST2071, P205-S6297, P205-S6298, P205-S6247, P205-S6287, P205-S6257, P205-S6267, P205-S6237
Tecra A7-S712, A7-S612, A7-ST7711, A7-ST7712, A7-ST5112
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 1.40. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
BTW, I've heard that this only happens when you boot up on battery power.
Maybe you can confirm this...
Aug 13, 2008 | Toshiba Satellite A215-S5822 Laptop
Toshiba
If you upgraded from XP to Vista and didn't exceed the minimum system requirements for Vista, then that is why your laptop is "struggling to work". You should have done a compatibility check before the upgrade to see what upgrades you might have needed to install Vista, such as RAM (usually adding the maximum amount of RAM that your MotherBoard will accept/recognize will get you going with Vista. Otherwise to get your laptop back to speed you can reinstall XP (XP runs on a lot less resources than Vista requires). You mention a graphics card, and I can't imagine one that would require you to upgrade to Vista yet, though I could be wrong.
Good Luck.
Nov 16, 2007 | Toshiba Satellite A130-ST1311 Notebook
Computers & Internet Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
