Question about Dryers
I need to either replace or reinstall the belt on a GE Dryer (DDG8280GCLWH), and I was looking for an exploded view or parts breakout to show how to access it to repair.Would appreciate feedback and/or where to go for this info....Thanks!!
  • Dryers Master
  • 8,220 Answers
To replace the belt you need to get the front off. Open the door and get the scews of that hold down the top.
get the screws off that hold the front and get that out yer way. check the slides and rear bearing for wear. then slide the belt on the drum. Put back the idler using the rear hatch. Replace the front, turn the beast and make sure it is not binding. Check connections Hit the start button.
Posted on Dec 15, 2008
GE gas dryer model #DPSR475GW0WW how to get to belt ?
Go to www.repaircliic.com and enter DPSR475GW0WW. With luck, you will be presented with a list of common replacement parts and may be able to view a generic GE dryer video that will show you how to access the belt.
Feb 13, 2017 | GE Dryers
I have a Simplicity dryer that needs a drum belt. Mine snapped. The rest of the dryer works. Do you have a universal belt that will fit this model. It is old. I do not know where to look for the model # as...
the model #dvlr223 is missing some numbers and letters at the end, if you can find the whole model number, open the door and you should see a decal with the model and serial number, you can go to www.searspartsdirect and enter your model # and you will get an exploded view of all the parts for your dryer, try to get the part # and find it local, they charge alot for shipping
Sep 30, 2010 | GE DVLR223 Dryers
How do i oil the belts? The dryer squeaks every time its turned on?
You don't oil the belts on a dryer. This will cause the belt to slip on the motor shaft and/or drum. Oil permiated into the metal of the dryer drum can ruin it causing any replacement belt to slip as well.
If the dryer is squealing, you probably need to lubricate the idler pulley wheel at the axle point (also known as a tension pulley). If this is a GE model they usually have drum slides and a drum bearing that support the front of the dryer drum as well. When they wear down, they begin to make noise. The drum slides are made of teflon and not only help support the drum, but ensures it turns smoothy. You may need to replace both the drum slides and the drum bearing.
If the model number is correct, the part numbers are as follows:
Drum Bearing - WE3M26
Drum Slide - WE1M481 (Blue), WE1M333 (White)
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
If you have any questions, or if your model number is different from the one you listed this question under, please post back and let me know. I hope this helps you.
Feb 24, 2010 | GE Profile Wizard DPSE592EAWW Electric...
Need exploded pic of dryer and instruction on how to replace belt it is broken
Searspartsdirect.com has some excellent exploded view parts diagrams you can refer to. Two other sites you may also try are pcappliancerepair.com and appliancepartspros.com.
For dryer belt routing diagrams, refer to repairclinic.com. Click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section.
If you need further assistance please let me know. I hope this helps you.
Dec 29, 2009 | Dryers
Electric dryer - Replace timer ? GE DDE7206MCLWH
Here is the best way I have found to get replacement parts.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 16, 2009 | GE DCSR483EA Electric Dryer
Kenmore Series 80
You can find an exploded view at Sears Parts Direct, as well as get P/N's for the parts needed. I suspect the roller assembly came apart which caused the belt to fail.
You will need your Model number to locate the exploded view. If you can not figure out the routing from that, then order the service manual from Sears. It will show the routing and describe how to assemble and test most all aspects of the appliance.
Jan 15, 2009 | Dryers
Want to make sure the dryer belt is put on right
Your issue is as follows;
"want to make sure the dryer belt is put on right"
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
This link shows belt routing for most makes and models.
Note: you may need to enter your model number to locate your particular models belt routing diagram.
http://www.repairclinic.com/0079.asp
In an effort to improve my quality of answers, please show your appreciation by rating the effectiveness of my answer.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 16, 2008 | GE Dryers
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
Model DE590 dryer needs drum belt replaced. I need instructions on how to do it.
Your complaint is: "model DE590 dryer needs drum belt replaced. I need instructions on how to do it."
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site. You may need to enter your model number; DE590 to gain access to your information.
This link shows the belt and cost.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1246110&PPStack=1
This link shows the belt routing, use diagram E
http://www.repairclinic.com/0079.asp#DiagramE
This link shows disassembly, exploded view directions. http://www.repairclinic.com/0100_18.asp
All service is performed from the front except for the installing the belt back onto the idler pulley. That procedure is done through an 8" removable panel in the rear at the bottom.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Jul 13, 2008 | Maytag Dryers
Dryer belt replacement
Here's a URL to a website showing an exploded view of the parts in your washer, and I noticed that one of those drawings shows the proper belt path for installation: --> http://www.partselect.com/MultiModels.aspx?ModelNum=CDE6000&searchTerm=&RefineSearch=0 Hope this helps! :)
Aug 02, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
70 people viewed this question
Top Dryers Experts
