Question about Sylvania 6727DE 27 in. TV/VCR/DVD Combo
Problem w/ fan running all the time
We just purchased this TV about 2 months ago. We have not really used the VCR and have only used the DVD player a couple of times. The fan runs about 90% of the time even though we haven't been using the VCR or DVD. We don't know if this is normal or we are just hearing in because the tv is in a room that is typically quiet. Is anyone else noticing this?
  • 979 Answers
Fan noise is normal...accordianman
Posted on Feb 29, 2008
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
We purchased an AKIA TV Type TR2136 Model CFTD2085 from a friend it has a DVD and VCR combination but we didn't get an owners manuel to assist in the use of the DVD and VCR. I want to know how to get an...
look on the back of tv for a 1800 number to call for help and if there is one call they should be able to help you also can search the net for akia manuel with your model.
Mar 07, 2009 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
50 inch insignia plasma
THIS BRAND OF TV IS NOT REALLY RELIABLE AS IT IS ECONOMICAL YOU SEEM TO HAVE A POWER SUPPLY PROBLEM MOST LIKELY A POWER CONTROL BOARD ISSUE .
IT WILL BE MORE ECONOMICAL TO PURCHASE A BETTER BRAND NAME TV AS THE INSIGNIA BRAND PRODUCT IS ECONOMICAL PARTS ARENT AVAILABLE.
Feb 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Need Manual
You can easily download a pdf of the manual from the LG site. I looked it up myself.
Nov 01, 2007 | LG RC199H DVD Recorder/VCR
Sylvania 6727DE 27 in. TV/VCR/DVD Combo Logo
41 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
