Question about RCA 32V420T 32" TV
Gap in screen
I moved recently and when I turned on the tv there was a 2" gap in the screen from the top. I know a little about electornics what is this problem call and what is the best way to fix it or is it not even worth my time? Thank you.
    Novelist:
    Champion:
  • 275 Answers
What do you mean "Gap in screen"? Is it that there sis loss of picture information for a 2" wide strip, somewhere at the top of the picture, or is that there a reduction in hieght of the image? Please clarify, to assist me in giving you a better diaganosis.
Posted on Mar 16, 2007
SOURCE:
My digidoor 1000n motor recently did not close all the way leaving a gap of about 60 mm and yesterday the gap seemed a bit bigger more like 100 mm how do i set it to close fully
on the rail there should be 2 cylindrical black magnetic read switches with white wires connected to them.
Those are the open and close distance units
sometimes they come loose and move with the vibration of the motor when opening the door
Nov 30, 2016 | Building Materials
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
you don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
Apr 27, 2015 | Avanti Dishwashers
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Hello im having a problem repairing my pistons and rings on my motor bike. can you plz tell me if the piston rings are supose to spin all the way around or are they both ment to lock in the groves for them
howdy.if your bike is a two stroke the ring has a pin in the piston groove to stop the ring turning.on four strokes the ring gap should be off set to each other and generally placed between 20-25 past and 25-20 to [like a clock] but no where near the side of piston at little end pin.also use a little oil in grooves to lubricate while fitting rings.some rings have angled edges so check wether they go top or bottom directions in manual or packaging with new ring sets.most rings will be marked to guide you.have fun and good luck.cheers
Mar 21, 2011 | Yamaha DT 125 RE Motorcycles
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
HOW TO FIX A GAP BETWEEN FENDER AND DOOR ON 1989
loosen the bolts and move fender back a little bit then tighten the bolts when the fender is where you want it.
Oct 15, 2009 | 1989 GMC Sierra
Spark plug
The gap is .025
Please remember to rate this fix.
Oct 26, 2008 | 2006 Subaru Legacy
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
SHADOWING
jesus have you move that tv thats new to me but surely techman know about.....good luck
Aug 08, 2006 | Optoma RD50 50" Rear Projection HDTV-Ready...
RCA 32V420T 32" TV Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
