Question about Hitachi 42HDT50 42 in. HD-Ready Plasma Television
Hitachi 42HDT50 42 inch
Does anyone know how to turn off the chanel display on the tv? On the bottom of the screen there is a small rectangular box that contains the chanel number. I can't seem to turn that off. Please help. When I change the aspect setting to expanded it disappears but on the other aspect choices it remains on the screen. Thank you.
    President:
  • 2,992 Answers
You can download the manual from Hitachi here:
http://www.hitachionlinestore.com/manuals/32_42_50HDT50.pdf
All should be covered there.
Posted on Dec 19, 2008
SOURCE:
My hitachi digital hdtv has always had cable hooked to it,and now i have no cable and i cant get the digital chanels to work with the antenna
The set will need a digital box to receive digital channels as it does not have a digital tuner in it--it is a very good set.
Nov 27, 2012 | Hitachi 43UWX10B 43" Rear Projection...
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
Remote for hitachi 52 inch projection tv not working
1st step, replace battery of remote, no result, 2nd step, check / replace Remote Sensor of TV.
Aug 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
HITACHI 65XWX20B - How to disassemble the cabinet?
The 65XWX20B comes apart in 2 pieces - there is a top half and a bottom half.
- The bottom half houses all of the electronics, projection lenses, etc. It is very heavy and should be moved with care.
- The top half is basically just the screen.
I have moved this Television multiple times, even up and down from a 3rd floor apartment!
- First remove the screws holding the top and the bottom, the important ones are on the sides of the TV.
- This is important, I suggest 3 people do this part: Slowly lift the top away from the bottom half of the TV, but -not- very far. There is small wiring harness that that attaches the top of the TV to the bottom to a circuit board. This must be unplugged by one person while the other 2 hold the top half of the TV slightly above the bottom half. Note carefully where this plugs in so that you can reassemble easily.
- Once this is disconnected the TV is much easier to move, although still quite heavy and bulky. Do not turn the TV on its side - keep it upright while moving.
Reverse this process to put it back together.
Once you have done it once it is quite easy.
Good luck.
Jul 29, 2008 | Hitachi Director's Series 65XWX20B 65"...
Rectangular Black Box Covers Lower Half of the Screen
I found this because I"m having the EXACT same problem with my DVD. Very frustrating that nothing works....
Feb 10, 2008 | Sony DAV-C450 System
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
JVC Screen problem
using your remote ,off the close caption. the black rectangular box that you see for the message but since you have message in the box. that why you see a rectangular black screen.
Jan 09, 2008 | JVC AV-32D305 32" TV
Screen frozen
Dec 29, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
My TV turns a Green scren
hi have a samsung 50 inch plazma tv . But saddenly it turned out be green screen, i am realy mad becouse i bought it $3200 on july 2007. please give me any helppfull idea.
thanks biruk.
Jul 03, 2006 | Miller TELEVIDEO 995 TERMINAL W/ GREEN...
Hitachi 42HDT50 42 in. HD-Ready Plasma Television Logo
164 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
