Question about Casio EXILIM EX-Z1000 Digital Camera
Self-portrate i am trying to find out if it's possible to set-up my camera in such a way that it would take a picture by itself,without me pressing the button,i have got casio ex-z1000.I was trying to find this option but no luck,also manual doesn't say a word about it
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Follow the instructions in the "Using the Self-Timer" section beginning on page 81 of this manual.
Posted on Jan 22, 2013
  • kakima Jan 22, 2013
CanadaBruce
  • 58 Answers
SOURCE: Flash not working
Sounds like a burn out, or a bad lamp.  The flash is subjected to a huge jolt of electricity each time it fires, and breaks easily, especially when hot.   If you are taking many flash photos, you should stop after 15 or so, to let the flash unit cool.
Good luck with Casio, if you are still under warranty.  It will probably mean mailing them the camera for fixing, or replacing.  Sometimes you can take it back to where you bought it for repair.
Posted on Dec 06, 2007
mcomijohns
  • 477 Answers
SOURCE: I dropped my Casio EX-Z1000
Unfortunitly when ever a digital camera is dropped it can cause the lens to come out of alignment this is what causes the error or problem. The len has several moving parts and can be replace most of the time it knocks the focus motor and zoom motor out of sync thust causing the lens to go out to try and post and sience the camera can tell the alignment is off then the lens goes back in. The repair for this should be around 100.00 I just got through fixing 2 of these for the same problem. Sorry but I hope this helps.
Posted on Apr 07, 2008
Doorguy27
  • 30 Answers
SOURCE: self timer? casio exilim ex-z80a?
Not 100 percent on this model. But most point and shoots are the same for things like that. there should be a O' type symbol on your point and shoor, ether a button or a on screen option. it likes something like O' but put together
Posted on Feb 10, 2009
  • 11967 Answers
SOURCE: My casio ex-s10 won't turn on. It beeps and beeps
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
  • 84 Answers
SOURCE: I have a broken LCD screen on my Casio EX-Z1000
First of all, you need to buy a new lcd from here: http://www.ownta.com/casio-ex-z1000-digital-camera-repairing-lcd-screen-for-replacement.html
Then, you can try to buy a opening tool, and replace the lcd by yourself.
Good Luck !
Posted on May 26, 2010
The self-timer on brand new my Nikon D3100 isn't working. It takes 30 seconds (not 10 or 2 like it should) to try and take the picture, but the lens just closes, never opens till I click on the sh
Do you have it set to bulb, it maybe haunted. just kidding.
Go to menu then Timers? AE lock and set your self timer number of shots the camera can run by itself but you have to set it
Nov 09, 2012 | Nikon D3100 Digital Camera
I can't remember how to or what setting I press to have the camera take a picture by itself; I have set the self timer to 10 seconds but I do not remember how to tell it to take the picture. I have a...
Press the self-timer button (marked with a one-handed clock). Use up/down to select an option. Start the self-timer by pressing the shutter release button.
Jul 20, 2011 | Canon Powershot SX110 IS Digital Camera...
I have canon a640 camera. I am getting problem regarding taking pictures as the flash is not working. I have tried it on Auto mode, Portrate, landscape and others the result is same. Please help me in...
make sure the dial at the top of the camera is set to AUTO or the green camera icon. When you are in position to take a picture, press the left button on the circle pad on the back of the camera; it should look like a SQUIGGLY ARROW this is the sign for flash. that button should turn it on, off, at automatic based on the current lighting.
Hope this helps!
Mar 14, 2011 | Canon PowerShot A640 Digital Camera
How do i get the canon powershot tx1 to self timer. i want to take a picture of my family without having someone to hold the camera. i want everyone to be in the picture. i set the self-timer but it wont ...
Press down on the multi-controller (marked with a one-handed clock), then use up/down to choose between 2-second, 10-second, and custom delay. Start the self-timer by pressing the shutter release button.
Jan 10, 2011 | Cameras
Where is the self timer on the c-3000 digital camera
try to check this path: Press the Menu button, then press the top/bottom arrows on the Jog dial to select DRIVE. Press the right arrow and press the top/bottom arrows to select. Press the left arrow on the Jog dial to confirm the setting. If you take a
picture without pressing the OK button, the setting will be valid until the Menu is canceled. To take a picture using the selftimer, when the shutter is released, the Selftimer/Remote control signal lights for
approx. 10 seconds then blinks for approx. 2 seconds before the picture is taken. To stop the activated selftimer, press the Menu button.
Sep 06, 2010 | Olympus C-3000 Zoom Digital Camera
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Problem with nikon coolpix 8700
Same problem that would not allow me to take a picture without pressing the LOCK button on my Nikon 8700. Here is how I believe I fixed the problem:
Turn the camera ON.
Press MENU button on your camera to bring up the menu.
Scroll down to SET-UP, open the SET-UP menu by scrolling right.
In the SET-UP menu, scroll all the way down to FUNC (Controls) on page 2/3 , open the FUNC (Controls) menu by scrolling right.
You are now presented with 2 options:FUNC and AE-L, AF-L)
Select the FUNC option by right scrolling.
Choose the 2nd option: i.e the mountain, flower and timer icon (distance, macro and self-timer icon) by right scrolling.
Press the MENU button to get out of the menu.
Attempt to take a picture without pressing LOCK.
Should work! Anyways, it worked for me.
Cheers.
Sep 28, 2008 | Nikon Coolpix 8700 Digital Camera
Problem with coolpix 8700 camera
Turn the camera ON.
Cheers.
Timer on samsung digital camera?
Sure ... be sure to use a tripod or other device to place the camera for stability.
  • Set the MODE DIAL to your desired photo setting
  • Press the SELF-TIMER button on the button pad (looks like a clock/timer on the right button pad)
  • There are three settings
    • 10 SEC - 10 seconds will pass until the picture is taken
    • 2 SEC - 2 seconds until the picture is taken
    • Double self-timer - a picture will be taken after 10 seconds, and then after 2 seconds a second picture will be taken.
  • Press the SHUTTER button to begin the timer.
  • Jump in the shot! =)
Please rate FixYa! ThankYa!
Dec 15, 2007 | Cameras
Casio EXILIM EX-Z1000 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
