Question about Dryers
I replaced both limits ,heat element, timer,the dryer now overheats and burns out fuse.the vent hose is off machine
  • Dryers Master
  • 8,220 Answers
I have come across this before. Here is what I think might be the problema. Keep in mind as the filter housing gets more and more blocked it tends to trap more and more lint in the opening between the drum and the filter housing. This causes a big ball of lint to glob up in that opening. To properly clean it you must remove the filter housing. That means you gotta get the front off and remove the tub. Then remove the screws holding the filter housing below and above and get it out of the dryer. Wash it down. Blow out the rest of the inside of the dryer. Air must be able to move freely throughout a dryer. So get the filter out. pop the top with a putty knife, remove the front panel screws. raise up on the front panel to keep from breaking the bottom panel clips. take the idler loose, get the drum out. then get the filter housing out. This is not hard.
Posted on Dec 15, 2008
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
My 700 series dryer 67741600 will not heat is it the heating element or could it be something elsse
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Additional Check points.
  • Test the centrifugal switch
  • Test the timer motor
Oct 01, 2009 | Kenmore Dryers
No heat inGLEQ2152ESO what's the solution?
2. Heating element
3. Thermal fuse
4. Check the operational value of the high limit thermostat as well. replace if found to be faulty.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
No heat, changed element, still no heat
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
((If the timer control module becomes unstable, it will also cause this no heat issue. If thermal fuse and thermostat are OK and in working order, replace the timer.(uncommon issue but possible)
Aug 13, 2009 | Dryers
No heat in dryer model # 96591420
2. Heating element
3. Thermal fuse
Jul 31, 2009 | Kenmore Dryers
Dryer won't heat, otherwise functions. we unplugged the dryer and reset the circuit breaker although it did not trip. is there anything else that we can do before we call to have it repaired?
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective. It can be tested with a Multimeter.
Jul 29, 2009 | Kenmore Dryers
Dryer turns on, but does not heat up? is this the heating element?
***If the Thermal fuse is in good conditon, you will need to replace the element.
Jul 24, 2009 | Dryers
Dryer does not heat up. Power and element are ok.
Jul 18, 2009 | Dryers
Will not heat
Jul 16, 2009 | LG DLE7177 Dryer
I have a kenmore model 68741 that won't heat. The heating element is good along with the thermo cutoff and hi-limit thermostat. I am getting proper voltage at the heating element.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 13, 2009 | Dryers
Dryers Logo
50 people viewed this question
Top Dryers Experts
