Question about Miele 24 in. G881SCI Built-in Dishwasher
Miele NOVOSTELLA PLUS Dishwasher Drain light
Drain light The dishwasher drains properly at the beginning of the cycle but not at the end. I removed and cleaned th drainage pieces but the issue persists
  • 9 more comments
  • joeharb962 Dec 14, 2008
    Thanks. I looked there and there is no debris
    No blockage threre
    when I run the DW with the drain detached (pointing to a garbage can, the water comes out full strength. If I attache it to the garbage disposal (was not attached to that in the 1st place) it does not...
    didn't know about the plug in the garbage disposal. Thanks. However the DW was not connected to it at first. It connects into its own drain pipe. Is it better to connect it to the disposal? and If sodo I still need to connect it to the air vent that sits on top of the sink?
    That would make sense. How to reset the timer?
    Thanks for your persistance. I think I got it, we'll see. A pistachio shell in the top part of the drain (the air intake next to the fosset on top of the sink)along with a plate tag.
  • joeharb962 Dec 15, 2008
    the airgap was 90% clogged. Testing a cycle now. what if it was the main control board?
    Also if the air gap was clogged, would that stop the cycle from finishing?
    What is the filter light for?
    Thank you all for your help. The issue was a pistachio shell in the air gap. he reason why it was working at the beginning of the cycle probably because the startupdrain cycle is short, and at the end, as the drainage cycle is longer, the sensor senses the slow drainage thus stopping the cycle.
    Drumbanger insisted the clog was in the drain pipe, which led me to look in the air gap and find the issue. All the other suggestions were pertinent. Thank you.
    Sergeant:
    Champion:
  • 283 Answers
Hi,please dont rate me if this could not fix your problem. Since at rhe beggining it properly work to drain then it stop after cycle so it mains that their is nop any debris that will clog on the hose. Check the gate bulb on the hose, it might not work properly after the cycle. thank you.....
Posted on Dec 15, 2008
  • 145 Answers
You mite have a bad board
    Master:
  • 416 Answers
One reason is partially clogged air gap.
The air gap is the small chrome piece that sticks out above the sink on the kitchen counter.
Another reason is the faulty main control board in the console. The dishwasher simply can not finish the cycle.
Good Luck
  • Grigory Zyryanov Dec 15, 2008
    If it is a main control the dishwasher will stay on and the timer not corresponds with the actual amount of time. And it will never go to drying cycle. It will stuck on the rinse or washing cycle and will not drain.
    If it was just air gap the washer should complete the full cycle.
    Good Luck
  • 4,806 Answers
Hi there
I don't think is the dishwasher as you have explained that the machine empties at full strength when not connected to the waste disposal unit.
have a look at the waste disposal unit for any blockages or objects
kind regards
Posted on Dec 14, 2008
  • 4 more comments
  • Lee Hodgson
    Lee Hodgson Dec 14, 2008
    also check outside at where the waste comes out for any blockage
  • Lee Hodgson
    After you have cleared the drain, pour hot water down it to clear everything properly
    kind regards
  • Lee Hodgson
    Lee Hodgson Dec 15, 2008
    Hi again
    Check every outlet pipe from the dishwasher to the waste disposal for clogging, check the outlet pipe at the machine itself (you may have to remove the pipe to check it at that end too)
    Once all the water pipes are clear and the waste disposal is too, you should be good to go, test a short cycle to find out
  • Lee Hodgson
    yes sorry clean the air gap, it can prevent water flow
  • Lee Hodgson
    "when I run the DW with the drain detached (pointing to a garbage can, the water comes out full strength."
    If it was the control it wouldn't do this as mentioned by you
  • Lee Hodgson
    it could be the
    Intake/Drain fault indicator
    This is essentially to alert you that the Waterproof system has
    activated, though it can also simply mean that the filter is blocked.
    or does it come with Eco-sensor?
    this feature uses light to gauge how clean the wash
    water is and can cancel a fill and reuse the water if it is clean
    enough. This can save over two gallons of water.
    regards
  • 275 Answers
Doing some thinking with you, and since you say that the dishwasher does drain watter properly at the beginning, that indicates that the water pump is working fine, but at the end it seems to have a little trouble, then this makes me think that is not a water pump issue but a timer issue itself, meaning that the dishwasher is not timed properly to finish the whole thing. You might want to look into reseting the timing settings on your dishwasher.
  • Alan R
    Alan R Dec 14, 2008
    I tried to look up for some manuals for you to see how reset timer, but I dont have specific model # of your DW, BUT this is a website where you can find the manual by looking for model # : http://kitchen.manualsonline.com/manuals...
  • Alan R
    Alan R Dec 14, 2008
    Drain solenoid
    Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system.
    Timer
    Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
    Selector switch
    A dishwasher usually has one or more selector switches on the main control panel at the top front of the door. The switch(es) allow you to choose among wash cycles, drying cycles (heat or no heat), temperature of the wash or rinse, and so on. The switches tell the timer which cycle options to engagehope this information helps us figure something out!
  • 1,800 Answers
Hi.
  • Check sink drain and drain hose for restrictions
  • Unjam the motor
  • Unjam the pump
  • Check the drain valve
  • Check the drive belt
  • Test the timer motor
  • If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Good Luck
    Master:
  • 479 Answers
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    New water disposals have a "plug" in the connection stub for the dishwasher drain hose. This plug MUST be removed or the dishwasher will not be able to drain into the disposal.
    Genius:
  • 1,199 Answers
The water drain is cloged! disconnect expell hose from under sink and run a fine wire down through the hose (this will unclog it( work for us every time Also make sure drain is open!
    President:
  • 2,110 Answers
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
We've got an Meile Incognito dishwasher, model G 843 SCVi plus. It purges at the begining of the cycle and then seems to fill with water, but then the red Intake/Drain light starts to flash and the cycle...
I would start by checking the drain line where it is connected to the garbage disposal. Check and make sure there is no solid build up obstructing the discharge into the garbage disposal. You can go a step further by removing the dishwasher drain line for thorough check up
If it has been establish that there is no obstruction by other means. There may be a problem with the control board.
I would suggest cautious approach in making rush decision on replacing the board.
Here is a link to the manual
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G843%20Vi-SCVi.pdf
Aug 02, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Have miele g611sc dishwasher opened up after cycle lots of water and bubbles in bottom ??
Sounds like it is either not draining properly or the type of powder or tablets you are using is sudding up too much and will not drain away the bubbles.
The 611 is a small dishwasher and only requires a small amount of powder.
try running a few cycles with no powder and see if it drains the water away ok. if it does then it is the detergent.
if there is water left in the base at the end of the cycle check the drain hose connection under your sink and make sure there are no blockages on the u bend spigot where the hose connects. if the unit does have a fault like not draning then the inlet/drain light will lit up.
hope this helps
Apr 21, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Dishes not washed properly. Have tried universal plus at 65deg, the water does not seem to get hot until it is in the main wash cycle. Used to use the universal cycle at 55deg with no problems. Also the...
Hi
Thanks for using FixYa. Check the water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible.
This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Oct 28, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G881SCI Built-in Dishwasher Logo
506 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
