Question about 2wire Wireless-G 802.11g ADSL Gateway
Installation problem I am bay some used 2Wire Home Portal 1000HG USB/Ethernet External DSL Modem with 802.11b/g Wi-Fi. I have 2Wire Power Supply, but I don have Cat-5 EtherNet Cable. Can I use any Ethernet cable. I don't have user manuals, no software for installing the modem. What can I do, hove to install modem, hove to confirm parameters. Yes, I have a Wireless USB adapter WPN 111(NETGEAR). I hope that you can help me to solve this problem. Best regrades! Milan.
    Problem Solver:
  • 4 Answers
YES!!!!! IT DOES NOT HAVE TO BE A SPECIFIC ETHERNET CORD TRY A REGULAR ONE OUT FIRST IF IT DOES NOT WORK IT WON'T SCREW ANYTHING UP IT WILL STILL BE WORKING JUST FINE SO JUST TRY A REGULAR ETHERNET CORD
Posted on Dec 23, 2008
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
I have a 2 wire home portal 1000HW. We recently had a power failure and the unit stopped working. I have checked the power supply with a vom and it is putting out the rated 6V. I have tried multiple...
Check your current rating on the OEM power supply.. I think your power supply needs 2 amps at 6 Volts. The cheap ones at radio shack are usually only 2 ma.
Jul 05, 2010 | 2wire HomePortal 1000HW DSL Modem and...
My dsl light is on green but my power light is on red. After a while no lights are on. My router is a 2wire that's about a year old
These 2Wire devices are known to have their wall-wart weaken over time. Although you can measure the proper voltage coming from the wall-wart, when you load it with the DSL modem, the actual voltage drops giving you the red power light. The green DSL light may or may not be accurate while the DSL modem is not getting the power it needs. Look online or go to a store like Radio Shack for a replacement wall wart.
Aug 26, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I have a 2wire 1000hg dsl modem and it is in bridge mode. Apparently I need to reset the modem (get it out of bridge mode) so I can access the settings page. How do I reset this modem?
There should be a reset button on the back or side of the unit.
Using a paperclip, hold that button down for at least 30 seconds, which will reset it to the factory defaults.
Should do the trick!
Jul 13, 2009 | 2wire HomePortal 1000HG DSL Modem and...
2wire Home Portal 1800HW
This 2-Wire Home Portal is a DSL modem. It can be used by itself as a wireless modem. It cannot be hooked up to an existing modem.
Go to this link and download the user manual:
http://www.dsldepot.com/download.asp?fileid=96
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
May 05, 2009 | 2wire HomePortal® 1800HW Router...
Hg1000 home portal
do you mean the modem's ip address?
http://gateway.2wire.net
http://homeportal
http://homeportal/setup
http://192.168.1.254 (software version 3.7.x and higher)
http://172.16.0.1 (software version 3.5.x or earlier)
hope this is the one you're looking for...?
Apr 06, 2008 | 2wire HomePortal 1000HG DSL Modem and...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
139 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
