Question about Hitachi 53UWX10B 53" Rear Projection Television
Pulsating static when using pro logic audio setting
When I use the pro logic setting in audio setup, i get a pulsating static noise that seems to fade in and out every few minutes. It works fine when I go to stadium or rock arena.
  • 97 Answers
Replace audio amp? processor board. A filter in the Pro Logic IC is bad and does not detect proper signal cueing for surround panning.
Posted on Mar 31, 2007
There is an audio board that needs to be rebuilt or replaced as this is a common issue with these Hitachi's. It is the surround board.
Posted on Mar 30, 2007
Uplander shake when braking at high speed
It can be issue with brake system alignment.Get the brake assembly checked.Something is not right and out of its way causing these problem.----------
Click the help links mentioned below and go with the troubleshooting solutions to confirm what is exactly faulty in your case:-----Click the link :----Car shakes like the wheels are going to fall off http://technoanswers.blogspot.com/2012/11/car-shakes-like-wheels-are-going-to.html
CAR BRAKE PROBLEMS
It can be issue with master cylinder or the problem is there is still some air there in the system,that has to be bleed.Or else the parts replaced are not aligned properly/.I suggest everything back.
There are few help links mentioned below to troubleshoot the issue.
Click the link below and follow its procedure:-----
All types of brake problems and repairs http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
Brake Fade Issue? http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Car Brake lines have no pressure? http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal? http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html
Feels Like Brake pedal Pulsating http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
============These will help.Thanks.
Nov 23, 2012 | Chevrolet Uplander Cars & Trucks
93 jaguar clicking sound when i press on the brake
Few latest troubleshooting help links related to these problem.
ABS light stays on but brakes work fine? http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
Brake Fade Issue? http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html Car Brake lines have no pressure? http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html Car Brakes Dragging? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html Car Brakes grabbing? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html Car Brakes Pulling? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html Pulsating Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html Spongy brake pedal? http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html Hard Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html Fading Sinking Brake pedal? http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html Brakes make Grinding noise? http://repairhelpcenter.blogspot.in/2012/06/toyota-corolla-brakes-make-grinding.html
These will help.
thanks.
Jul 07, 2012 | 1993 Jaguar XJ6
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Pulsating hard drive on startup and off
To eliminate a software problem, I installed another hard drive with the same operating system, and the problem still existed.
I also flashed the BIOS with no results.
The most logical conclusion is that the problem lays with power supply.
A new power supply was ordered today.
Jan 13, 2009 | Dell HP-P2507FW Power Supply ** FREE...
Pulsating grinding noise from front differencial
It sounds like to me front wheel bearing hub assembly.
Nov 29, 2008 | 2000 GMC Jimmy
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
56 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
