Question about HP Pavilion tx2120US Tablet PC
"USB Device Not Recognized" - any usb device
Any device I insert into any of the four USB ports on my laptop results in a bubble from the task tray popping up informing me that the "usb device cannot be recognized". The only thumbdriveI've tried to use freezes the laptop as well.
This is a recent situation. USB devices used to work. I can't recall an incident that'd cause the USB ports' malfunction.
From the laptops first day with me it had XP pro installed (by me) in place of vista basic. Toshiba doesn't provide XP drivers for this laptop model or XP compatible bios updates. I've yet to try vista and play with power settings and drivers.
The cmos doesn't provide an option to disable/enable USB devices/ports.
Removing all unknown USB device drivers (hidden and shown) didn't fix the problem.
Reformatting the computer didn't fix the problem
Updating to the most recent bios didn't fix the problem.
Suggestions?
I have the same problem with my laptop her is what I tried:
  1. Un-installing all USB drivers
  2. Shutdown computer
  3. Unplug from wall and removed the battery
  4. Waited 30 mins (3 & 4 I read elseware)
  5. Powered back up
I ended up doing a factory reset
nothing has worked so far
Also the front USB device has stopped working altogether (after putting a device in it the 'not recognized' ballon does not show up but the device doesn't work)
I also noticed that when going into the device manager and clicking properties on Unkown Device under the USB section it says that no driver is installed
  • drewmcd621 Dec 15, 2008
    Thank you for your solution,
    The problem is with the internal USB ports, do you think sending the laptop to HP is the solution?
    Problem Solver:
  • 4 Answers
It May just be a hardware problem... try putting in some new usb ports.
Posted on Dec 15, 2008
  • sakao Jan 01, 2009
    if it is under warrenty then they will fix it... if not i suggest a local repair shop... check for prices!
Starts up. Password required but keyboard not typing correctly. Blue tooth keyboard not recognized.
The most likely cause is that the keyboard needs a new battery in it, inserted on the underside. After that it may be that the small keyboard comms dongle in a USB port is not making proper contact. Pull that out and insert it a few times.
Mar 26, 2016 | Tablets & eReaders
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
USB keyboard not working
The biggest problem with tablets and phones is the micro USB socket. They are easy to break if you put them in the wrong way round and it is not always easy to see if they are connected correctly.
Check the USB plug and the the tablets socket are not damaged.
Check that USB keyboard works in another device and that another USB input device works in the tablets USB socket.
I am suprised it works at all. You state you are using Android 2.2 yet USB hostmode was only introduced with Android 3.1
There are some apps in the play store like USB device info which may help. For proper debugging you need an APK which is not for the average user. http://visualgdb.com/tutorials/android/usbdebug/
But cables and plugs are 98% of the problem
Good Luck
Jul 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
I plug my zeepad into my comp with a usb plug it tells me it's looking for software to download but some other screen pops up asken me to put in the software disk that came with my device but I never...
Same problem happens to me when I insert something into one of my computer's USB ports, such as a flash drive, it doesn't get recognized. This happens with things other than just a flash drive as well, like my iPod. I have numerous USB ports on my computer, but they all act the same. I'll insert a flash drive and even after it's not automatically recognized, I'll go into "My Computer" and it shows all the "Removable Disk" drives as being empty. I'll click on one and a prompt will come up and say, "Please insert a disk into drive F" or whatever drive I happen to click on. I've tried this with all the drives but to no avail.
http://mhelpdesk.com/field-service-management-software/
Oct 06, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
When i plug in my velocity cruz reader into the usb port it tells me that the USB Device Not Recognized?????
Chances are the reader is defective. Try to plug it into another computer to confirm this. If it works try another USB device to confirm that the port is working.
Jul 21, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I am attempting to run full reload of this system using an exterior hard drive with usb connection. The reload will not start using thid device. I did not buy the docking station for this system when I...
Most laptops cannot boot up from a USB device/hard drive. Check the BIOS configuration to see if the USB is available in the boot order devices. In this case the USB driver is not available for use until Windows is installed.
If the USB is not available in the BIOS Boot order then you need to reinstall Windows using the installation CD in the CD drive..
Nov 24, 2010 | Compaq Refurbished TC1000 1GHZ...
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Gateway Pen Drive .... not recognized on Windows XP
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Nov 22, 2008 | Gateway M275 Tablet PC
Pen problem
to connect yo,r pen in usb port and anotner one solution is to uninstal your usb drivers in yo,r devicemanager and restart your system then connect your pen
May 08, 2008 | Fujitsu Siemens LifeBook T3010 Tablet PC
HP Pavilion tx2120US  Tablet PC Logo
1,477 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
tosin_christ
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
