Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Westinghouse LD-3240 input select menu keeps popping up.
    Genius:
  • 1,182 Answers
Look for any jammed button on your remote or on the TV. Just recheck on the settings and if necessary change it to factory default settings. If you have problem still, switch off TV, switch off Power and remove plug and wait for 48 hours and retry.
Posted on Jul 29, 2012
SOURCE:
How do I set hdmi input for Westinghouse model LD-2240 TV?
The whole idea of HDMI is it is plug and play, plug it in and it should auto switch to HDMI,if not on remote go to source, press input, then pree HDMI
Mar 04, 2018 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How to turn off internal speakers on the ld-3240
If it has that feature it will be in the menu somewhere and require the original remote, if all else fails look at the owner manual.
Dec 20, 2012 | Westinghouse Televison & Video
How do you get to channel 60 without going through the set-up menus on the Westinghouse LD-425 series
maybe you need the dvr or their box and use that into input (channel 3 or 4) and use the remote.
Sep 06, 2012 | Westinghouse LD-4255VX 42" Edge-lit LED...
My tv input won't change
try to use ur channel up or down buttun on ur settings menu to change from component to the setting u want
Jul 01, 2012 | Westinghouse Ld-4055 40" Hdtv Led Class
Need codes for westinghouse LD-3240
The code is under Samsung. I have the same tv.
Nov 26, 2011 | Westinghouse Televison & Video
I purchased a Westinghouse 32"
http://westinghousedigital.com/wordpress/wp-content/uploads/2010/05/Remote-Codes.pdf
That should give you the codes you need. Hope it helps.
Sep 06, 2011 | Televison & Video
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
391 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
