Question about Smeg Dishwashers
Smeg sth 905 dishwasher technical name to front plastic apron the that pushes up on closing
LVS1251X1
contact the manufacturer via their web site for a manual or tech support.
Jun 04, 2014 | Smeg 24 in. DWF614SS Stainless Steel...
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Need Dial
go to http://au.mouser.com/Electromechanical/Knobs-Dials/_/N-5g22/
There should be something the same or very close to what you want.
Apr 15, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Dishwasher manual
Hi Rosemarygard,
You filed this question under Smeg DWF614SS. You can get the manual for that model here- http://www.smegtech.com/site/smeg/pdf_libretti/19590081906-GB.pdf.
Searching for model M4608AL isn't leading me anywhere, so hopefully it's some sort of subcategory of the DWF61466. If you realize that your Smeg is another model, go to this page and type your model into the field on the left- http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN.
I hope this helps.
Jan 25, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
80 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
