Question about Stamina Products Stamina SpaceMate E100 Elliptical Trainer
No instructions/manual w/ stepper
Just purchased a display SpaceMate Folding Stepper from GNC and it was not in a box and no set up directions or user directions were included - could someone please send me a copy of these items and also the best way to use it. I would appreciate anyones help and hope to start this new year off right. Thanks for all your help.
Rene'
A manual for my hers MS -93
Impex Home Gym MS-60 User Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > Impex Home Gym
Impex MS-60 Home Gym User Manual. Page 1 ... Assembly Instruction. Parts List ... 12-28-05. OWNER'S. MANUAL. Hers. MINI STEPPER. MS-60. IMPEX INC.
[PDF]MINI STEPPER
www.fitnessequipmentexpress.com/images/pdf/IPX017.pdf
Assembly Instruction. Parts List. Warranty. Ordering Parts. Model. MS-71. Retain This.Manual for. Reference. 100624. OWNER'S. MANUAL. HERS.
Nov 28, 2015 | Cars & Trucks
Need a Manual for a Kettler Power Stepper 7876-900
turn on i hope you know that part
adjust the resistance settings like to light then get on and start walking like climbing steps
Nov 09, 2013 | Cars & Trucks
Star trac sc4100
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
The following link will take you to the items we have available for your Star Trac SC4100. You can use the tabs on this page to see an owners manual, service manual and a diagram.
Star Trac Unisen Stepper Parts for Star Stepper SC3100 SC4100 SPORTSMITH...
Aug 14, 2013 | Exercise & Fitness
Stair master 4400cl Stepper making clunking sound user pedals when stepping
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
This can cause a clunking sound. For the replacement parts, please see the link below.
Why does one Pedal Drop on my Stairmaster Stepper
Apr 03, 2012 | Stairmaster 4400CL Stepper
User manual
Use this link to go to our Website and obtain a user manual and an owners manual by clicking on the manuals tab in the middle of the screen.
Stairmaster Stepper 4400CL Parts Spring Chain Battery SPORTSMITH net
Jan 28, 2011 | Stairmaster 4400CL Stepper
Needle sticking or not reading correct speed
Speedometer cluster is defective. Many GM oproducts used stepper motors in the speedometer cluster. speedometer, gas gauge, tachometer etc what ever is a movement indicator.
Do not purchase a used one or one that is "repaired" if the stepper motors are not replaced with motors made after 2005. repaired units cost a few hundred dollars. individule stepper motors can be purchased on EBay for less than $10.00 each. The cluster must be removed from the vehicle and dismantled carefully, knowing it is electrical device and may be damaged by static electricity. good luck!!
Jan 13, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
Left pedal on stepper falls to ground in workout
YOU MAYBE HAVING AN ISSUE WITH THE SPROCKETS THAT HOLD THE DRIVE CHAINS ON BOTH PEDALS. YOU CAN PURCHASE THEM SEPARATELY OR A COMPLETE HUB ASSEMBLY. TO REACH STAIRMASTER/NAUTILUS @ 1-800-864-1270
Feb 26, 2010 | Stairmaster 4600PT Stepper
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Stamina Products Stamina SpaceMate E100 Elliptical Trainer Logo
35 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Tom Chichester
Bill Boyd
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
