I have a hrmon kardon rec. a fuse hase blown, i am having a hard time locating 1 to replace it, where can i find 1?
    New Friend:
  • 59 Answers
Take the blown fuse to Radio Shack or look up 'Electronic Equipment and Supplies= Dealers' in the yellow pages. It shouldn't be hard to find.
Posted on Dec 17, 2008
Harman Kardon 146 receiver not turning on.
Possible blown fuse inside unit, unplug and remove the top cover
fuse should be near the power board and transformer. replace with exact fuse, "Never remove covers with the unit plugged in" Always wait 4 or 5 minutes after unplugging to remove the cover.Replace cover before plugging unit back in.
Oct 06, 2014 | Harmon Kardon Harman Kardon Avr 146 5.1...
Fuse box diagram
Instead of wasting time searching for the exact location, why not just remove each fuse 1 by 1, and replacing them as you go so you don't mix them up. If you have any blown fuses, you will find it in under 30 seconds. If you don't know the difference between a good vs blown fuse, ill post a picture to help you identify.
Dec 10, 2013 | 2008 Chrysler Crossfire
Fuse box ]
If you suspect you have a blown fuse somewhere,
Dec 08, 2013 | Toyota Pickup Cars & Trucks
Where are the fuses in the harman kardon 3380 receiver, I had a lightning strike which I think knocked out my receiver thru my outdoor speakers, it will not turn on, could it be a fuse and if yes, where is...
Hello Randy,
There are two options here: first, the power button is amber but unit still won't go. In this case try a 'factory reset' as per manual. If this won't work, it seems that the processor is gone (located on the display board) so you have to bring your unit into a authorized shop for repairs. Secondly, it might be just matter of some blown fuses which are located inside the unit on the transformer board. If after replacing (if they're blown) the unit still won't work or keeps blowing the new fuses, follow the first advice, meaning you have to bring the receiver to a service. To access the fuses, you have to remove the top cover.I wish you luck
Kostiko
Sep 12, 2011 | Harman Kardon HK 3380 Receiver
No start
INFO: Sounds like you may have blown a fuseable link. RECOMENDATION AND LOCATION: Check the fuse block located on the drivers side fenderwell, in this location you will find fuses and fusible links. This is a wire with which seems to have a thick insolation on it. To test you can pull the wire to see if it still hase a wire in it, if the link is blown there will be only insolation. . Hope this tip helps.
r/
David
Mar 02, 2010 | 1992 Ford Escort 4 Door
Short causing #3 & 4 fuses to blow
Hi Mopadge. I have the same problem with my avr210. Did you solve it? How? ... Thanks a lot.
Oct 23, 2009 | Harman Kardon AVR 210 Receiver
Harmon kardon 520
This usually happens when a 'Picco' fuse is blown. There are several of them. They are small, skinny fuses that look like resistors. The one you are looking for should be close to the power supply and located on the green circuit board. You must use an ohm meter to figure out which one is burnt out. It takes patients,but that stereo is worth the hassle.
Sep 23, 2009 | Harman Kardon AVR 520 Receiver
Blown fuse
Some hardware stores will carry these fuses as well. Remove the current one and look on the metal ends. It should be etched with the current value (3.15A most likely). It will be either an AGC or GMS fuse depending upon its size. The AGC will be about 1-1/4" in length, the GMS about 3/4".
Dan
Mar 31, 2009 | Harman Kardon HK 3370 Receiver
No speaker sound with hk 3480.
your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
Nov 20, 2008 | Harman Kardon HK 3480 Receiver
Subwoofer
Repeated fuse blowing generally indicates a blown power supply, or blown output stages or both. One thing to do is be sure that you have replaced the fuse with the correct type. A T stamped into the metal of the fuse near the rating, indicates sloblo or Time Lag fuse. A fast blo fuse, may work once, or more times, but will never replace a sloblo fuse in this type if unit. Good Luck, hope this info helps, don't hesitate to hit me back here for more help :)
regards
Graeme
Feb 13, 2008 | Harman Kardon HKTS 7 System
102 people viewed this question
 Grubhead
Grubhead
