Question about Avanti W789SA Top Load Washer
Avanti W789SA Water valve problem
My washing machine stopped taking cold water. Im pretty sure the problem is coming from the water valve. The model of the water valve is WV-21AE-11. Im having problems finding this part anywhere! Can you help me finding it or at least finding a part which will work with the washing machine.
  • 59 Answers
Where do you live.I know some chenese guys who sell the spare parts.
Posted on May 07, 2009
My machine wont spin or turn i took the back off the machine and in the tank there is water in it and wont come out
firstly,the machine will not spin if water is in it.the spin cycle starts when the tub is drained of all water.you seems to have one or a combination of these problems; drainage/blockage/pump motor/no signal/no voltage.does the machine complete the wash cycle?
Nov 20, 2012 | Avanti W789SA Top Load Washer
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
Washing machines got an error 49
is there any issues with the water filling? does it overfill, does the water not turn off and it begins to wash even while water is still pouring in? or fill very slowly like the water just trickles in? because im pretty sure not 100% with your model ive got no info on it but most F+P stuff has the same fault codes, but an error 49 is an issue with either the cold or hot water valve or both you may be lucky and its a dodgy wire come loose but if not and if you know how get a multimeter and measure the resistance of both valves if they check out all good you will need to replace the motor control module
Jan 20, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Water running from machine every time when i start to wash
Possible leak in the ddrain hose, the drain pump/valve.
It will be ideal to have a first observation with a good light below the unit to confirm.
Oct 31, 2010 | Avanti W789SA Top Load Washer
Drain hose cracked and leaks water
You just have to replace it. Try these sites for spares with your model number, etc:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 12, 2009 | Avanti W789SA Top Load Washer
Avanty w789SA
its the drainage problem .so either the drainer is getting blocked or the drainer is cracked and got faulty so needs to be replaced.
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Feb 26, 2009 | Avanti W789SA Top Load Washer
Help me ....
Yes ,simply replace the water valve (hot&cold)and your problem is gone.
May 26, 2008 | Avanti Top Load Washer W797
Hot water overflowing
thats a sure sign of a bad water valve contact avanti there a good company they may send you a new one
Apr 01, 2008 | Washing Machines
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Avanti W789SA Top Load Washer Logo
276 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
