Back to:
Tags:
Panasonic CT-32SL14 32
TV will not turn on.
posted by nurse1 on Mar 16, 2007
I used the remote to turn it on one day. It made a slight noise like it was going to come on but did not. It was having no problems up to that point. We did have a power outage a few days before, but it was working after the outage. It was connected to a surge strip. The chasis # is AP411.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 17, 2007
FixYa! (100)
Stargazer
Rank:Guru Guru
Rating: 86%, 238 votes
Are you sure your remote is working ? Did you try using the power button on your set? IF so, then something is wrong inside you set.
Possibly a power surge got through your supressor and caused a delayed reaction failure in your power supply.
Also some other part may have just decided to fail.
You need to have a tech check it out for you.
Stargazer
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TV will not turn on.:
I don't want to Accept this solution
Solution #2
posted on Mar 09, 2008
Not Rated (0)
JunZky_
Rank:Guide Guide
Rating: 88%, 9 votes
If Ur Techy Enough You Can Open The BAck cover and check if the fuse is busted then replace it , still if you see that the fuse is fix with no sign of burned or crack , you must then see a technician for a repair job
Thank You!
Can you Help with these Standard Televisions problems?
Panasonic CT-32SL14 32" TV
how do i turn off pip on a panasonic tv?
After running a few minutes, the TV shuts off on its own...
turned tv off for 20 minutes - had been working fine and...
My tv will shut itself down. The power button light stays...
Open the cabinet by removing the multiple screws around...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
