Question about Maxent MX-42HPM20 42 in. Plasma HDTV
Tv problem When you turn on the tv you see lines and the image start clickin for about 45 seconds this problem start for only 15 seconds and its getting worst. thx
    Problem Solver:
  • 11 Answers
What you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to work.
Posted on Jan 21, 2009
Toshiba sl738b
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Toshiba Televison & Video
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
Have 57 projection mitsubishi have no pic got sound makes a clickin noise then turns off.
your tv out signal not adentify by your projection just change your tv seting pron software stting
May 16, 2012 | Mitsubishi WD-57733 57" HDTV
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
TV turns on/off automatically at 1-2 mins intervals.
Replace the power supply, PN: BN44-00206A
It's easy to locate, but requires adjustments once it is installed. Panel voltages must be adjusted according the the specifications of the TV. There is a sticker on the back of the plasma panel which provides each voltage setting. You can reference this sticker to make the proper adjustment. Using a DMM, connected between chassis ground and the panel voltage you are adjusting, turn the adjustments on the power supply very slowly, until you are measuring the specified voltage within 0.5v. I hope this helps and good luck.
Mar 15, 2010 | Samsung PN50A400 50 in. HDTV Plasma TV
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Sk-19h210s turn on off
replaced the 2200uf 10v capacitor on the power supply board. cost 90 cents from Digi-Key on the internet and a couple of bucks for shipping. NOW MINE WORKS FINE
Jul 07, 2009 | Westinghouse SK-19H210S Television
Converter box turns off every 15-45min
reset it to factory defaults settings.press reset switch or power bur\tton for 10 seconds.
a
Jan 05, 2009 | RCA Analog (RCA) to Digital (VGA)...
Losing picture and sound
It needs a new bulb, same thing happen with me. jut get a bulb for this model and change it. if you call sony service, it will cost you about $500.
Aug 09, 2007 | Sony KDF-E55A20 55 in. LCD Television
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
96 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
