Question about Konka KDL32AT23U 32 in. LCD Television
How do i tune my konka 32inch to digital
Ive used my sky cable to use as an aerial.its also got freeview built in..so i thought it will go on..but it keeps saying no signal..ive tried tuning it in but maybe im doin it wrong..could u help me out..we havent been able to watch tv
    Genius:
  • 1,182 Answers
Just check whether the input cable jack has any loose contacts. Mostly this might be the reason.
Posted on Jul 29, 2012
3 Suggested Answers
SOURCE:
  • 35 Answers
SOURCE: adjusting screen size
Make sure you dont have picture cropping on in your settings. If you do, it will crop about an inch or more off all sides of your picture.
Posted on Mar 04, 2008
gopakumarg43
  • 76099 Answers
SOURCE: Konka TV Model K2173PM.
Hello
Just buy one Philips Universal Remote control model number [CL 034]. Konka is listed on its codes. Codes and proceedings are given here.
Codes
............ 0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Posted on Jan 27, 2011
Sky problem
Freeview has nothing to do with satellite. FreeSAT is the one that uses a satellite dish for reception. FreeVIEW is received through the aerial.
Also, don't fall for the "digital aerial" scam. I install aerials as part of my business. I've been to homes with aerials 20 years old, covered in soot from the chimney and they still pick up Freeview perfectly well. Equally, I've been to homes where the owner has bought some gold plated multi-finned "digital high gain" monstrosity that has awful reception characteristics.
If your TV aerial is okay, then just plug it in to your Freeview receiving TV and do the tuning.
If you do want Freesat then you will need a satellite dish along with a Freesat receiver.
Sep 04, 2014 | Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
How do i tune my konka tv to digital tv
Check for compatibility in the operation manuals of both.
Jul 28, 2012 | Konka KDL32AT23U 32 in. LCD Television
How do you tune in tv channels when you only have a signal input from a satelite dish and no sky decoder. TV is a sharp lc-32l400x with built in freeview. Can we plug dish straight into TV aerial port...
You require a satelite decoder/receiver for your dish and an aerial for your TV.
The choice is yours. Plug a satelite receiver, for freesat, into the A/V input on the TV or have an aerial installed for freeview.
Jan 19, 2011 | Televison & Video
Can you tell me how to tune in a channel when ppreparing to use a freeview box on a onyx sw 1536 ld
Unless you've got an "expensive" Freeview box that modulates its output on to the RF (Aerial) connector then you can't. Most Freeview boxes have 2 aerial connectors - 1 IN from the Aerial itself and 1 OUT to connect to the TV - BUT this is ONLY a PASS-THROUGH connection. This means that the digital Freeview signal which is decoded from the aerial signals is NOT output on the OUT connector and sent down the co-axial cable to your TV. Only the "old" ANALOGUE (not Freeview NON DIGITAL) comes down that co-ax. What you should do is connect the Freeview box to your TV with a SCART cable via the SCART connectors on both. You need to select the AV input on the TV using the remote.
Even if you do have an "expensive" box that does modulate the digital decoded programmes and output these of the RF OUT connector, you should still use a SCART cable as the picture produced will be far better
Hope this helps
Jul 06, 2010 | Televison & Video
Problems with connecting freeview box to a konka 32" tv
HI mullinsallya unplug it from the mains, plug the aerial into the hole which says RF in, then assuming its a Scart type, plug the Scart lead into the TV Scart socket on the freeview box, then the other end into the TV FULL scart if you have two, plug it in and switch it on, may need re-tuning due to the channel 5 fiasco. Menu button settings, or setup, or installation, if you see a "First Time Setup" use that, as it will wipe all previous installed channels and give you the latest channel config. , then usually its a case of save and exit or sometimes just exit by pressing the menu button again.
Dec 06, 2009 | Konka Televison & Video
Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Mar 03, 2017 | Televison & Video
No signal on teristeral but able to watch tv through sky
This could be down to several things so sorry if this is long winded but really needed more info from yourself...
Sky gets its signal from the dish mounted on your exterior wall.
your terrestrial signal comes from your terrestrial aerial be it external or internal.
If you do have an aerial cable coming into your property and it is connect to your television. Go into your TV MENU and set it away on Auto Tune if this does not come up with any channels. Try auto tune on your built in Digital tv ie DTV if it has this option...
If neither of these work then you need a new aerial or it needs to be re-aligned.
Personnally I would not bother with a Terrestrial Aerial You already have Sky installed so this will be fine for when the Whole of the UK goes digital. Dont be fobbed off by people telly you that you need a Digital aerial as your sky dish is already Digial anyway.
Hope this Helps
Little Dish Fitter
Apr 12, 2009 | Samsung 37 in. Flat-Panel LCD HDTV
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Cheers
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
Konka KDL32AT23U 32 in. LCD Television Logo
314 people viewed this question
Top Konka Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
