Question about Kenmore Elite 45986 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
HE3 Elite - there are no error codes - it just doesn't spin the clothes as dry as it used to. What could be the problem? I have no other complaints about this machine - it is about 4-5yrs old.
  • 92 Answers
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Posted on Dec 14, 2008
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore h2 error code
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore 46462 Front Load Washer
How do you get to the drain filter on a kenmore elite he3 washer to clean it?
The following link explains how to access the drain pump on a Kenmore Elite HE3 front loader to clean the drain pump:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
323 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
