Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Picture is not lined up
Auto focus does not work its like the lights are not lined up and tried to take it apart, but cant get the front screen off. i can get both sides off but the center is stuck. How do i get the center of the screen itself off? i need help to get tv back off to adjust projectors and need to know how to align everything
    Problem Solver:
  • 13 Answers
Is this an itc222 chassis ? if it is then there should be a 400ma fuse next to the flyback transformer that has opened up. usually replacing it will fix the problem
Posted on Dec 22, 2008
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes.
Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely.
If the camera does focus correct in the auto mode, then you can check, why it did not focus before.
Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
Apr 23, 2014 | Fuji Finepix S1500 10.0 Megapixel 12x...
Digital camera won't focus
I see your camera has a focus area. If you have a subject with enough contrasting parts in this area, the focusing should work fine.
You must know that not every subject can be focused on as quick or as good as you would like. If there are little contrasting lines in the subject, or when it is getting dark or there are dark and light parts in the focus area, that don't belong together, every camera can have problems to focus correct. Changing the ISO settings won't change anything for the auto focus.
But special when you try to shoot in almost dark places, you camera will have lots of work to focus and in most cases it won't work at all.
You could try to place an object with light and dark lines, on the same distance as the object you want to picture. Then by pressing the shutter half, when focusing on the object with much contrast, you can look if the camera can focus. If it is in focus, keep the shutter pressed half way down, while moving to the object you want to shoot a picture of. Once you have every thing in the frame as you want it, press the shutter complete.
Dec 27, 2013 | Vivitar Vivicam 5388 Digital Camera
My d80 wont take pictures in auto,P,S or A modes. Will click in M mode but no picture. What am I doing wrong? Treied to reset, but still does not work.
The camera will not take a picture in P, S, or A if the camera is in Auto Focus mode - and is unable to focus. Make sure that the Auto / Manual focus switch on the camera body AND the lens are BOTH in an Auto Focus mode. A tip off would be that you do not hear the lens focus motor running while trying to find focus.
If you do hear the focus motor, you may not have sufficient light on the subject for the camera to find a contrast "edge". In this case, the focus motor will hunt from where ever it is all the way in one direction, and then all the way in the other - trying to find focus. You'll need to provide more light or if you have the focus assist lamp (on the front of the camera) enabled - make sure your fingers are not blocking it while 1/2 pressing the shutter.
You can take pictures "all day long" in Manual Focus mode regardless of whether the subject is in focus or not. The lower left corner has a green circle or disc that indicates proper focus. Otherwise, a green triangle shape will be visible close by.
More info on Focus is available here. I hope this helps and good luck! Please rate my reply. Thanks.
Nov 07, 2011 | Nikon D80 Digital Camera with 18-135mm...
You push the button and it will not take a picture. I put new batteries in it and it still will not take a picture.
My HTsi Plus never seems to be able to Auto Focus on a subject, so when you push the shutter button half-way, it just flashes the focus indicator (telling you it is unable to focus). Try switching over to the "Manual Focus" mode. On the front of the camera there is a button labeled "AF/M". Push that button to switch to manual focus. If the camera is in manual focus, the external LCD screen will say "M.Focus". Now try to snap a shot. If that still does not work, there may be something wrong with the camera or the lens. So, try using a different lens in manual focus mode. If it still does not work, then I would say the problem is with the camera itself.
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
The screen especially words and numbers are blurry
hi there
there could be 3 cause to your problem
1= misconvergence
2= crt are weaks
3= out of focus
both can be ajust but dont try the auto focus
it is simply not working
convergence in menu
focus in back of front cover small block with
2 rows of controls look for focus and ajust for picture for sharper
Sep 30, 2010 | Hitachi 57G500 57" TV
The LCD-screen seems to work normal. But when we take a picture (camera-mode normal and record-mode normal) the result is overlighted and misty and full of horizontal lines. In video mode the camera works...
Try to use a different setting like a bright light setting to see if the apeture is closed down further and brings back focus.
the problem is the auto focus which can be going stray and is not setting right.So take time to shoot with the shutter button down to half to allow it to focus and then once the indication of the focus has confirmed to click.
If not contact Sony service for help.
Sep 28, 2010 | Sony Cyber-Shot DSC-T3 Digital Camera
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
Have green bow in top right and green shadows all over
your convergence board needs to be replaced..its out.thats why the bow in the pic
Oct 30, 2008 | Hitachi 46F500 46" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
