Question about 3Com OfficeConnect Remote 612 ADSL Router
My 3com officeconnect doesn't work after upgrding the firmware
I bought this 3com OfficeConnect model no. (3CRWDR101A-75) 3 weeks ago and recently it started to reboot every couple of minute, so i decided to upgrade the firmware, cause i thought it might fix the problem, and after upgrading to the new firmware the device did not work only the (Alert led, and the Power led)work while the (online led, and the Wlan led) keep flashing on and off every second how do i fix this problem
  • Aliandroِ Armando
    Aliandroِ Armando Mar 16, 2007
    ok, first of all thank you very much for your help, but i've tried to reset the router to factory defaults, but it didn't work
    but i've fixed the problem by my self and that was so easy
    first of all i downloaded the new firmware from 3com website
    then i plugged the Ethernet cable and restarted the modem, then i opened the command window by typing cmd in run window
    after that i typed (ipconfig /all) in the command window
    and i found a new default gateway (192.168.2.1) other than the one i used to have (192.168.1.1)
    i used it to log into the device's system by typinghttp://192.168.2.1 in the browser's address bar
    i logged into the device system and i found a web interface that help you to fix the device after an incorrect upgrade
    and i updated the firmware successfully
    and after that i rebooted the system through the same page and i went to http://192.168.1.1) and it worked properly
    thank you
    and best wishes :)
  • pierrearinsa Feb 13, 2009
    same here, I try to upgrade to firmware AR4505NW-A-LF-32_v1.10.00.A.bin, then the reset then the reboot, and now the router is just a firework... all leds blink, alert one too, and it some time answers to the dhcp, some time not, any way, 192.168.1.1 is not accessible anymore.
    is there a way to get older firmware?
    Novelist:
    Champion:
  • 202 Answers
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Posted on Mar 16, 2007
I'm having the same problem of WhiteFlag and followed the steps trying to resolve the issuse but this not halping when i reboot the router it's having the same problem
Posted on Jan 15, 2008
SOURCE:
Tip
3COM 3CRWDR200A-75 Firmware Download - All Versions
Hello
If you want earlier firmware versions of 3Com 3CRWDR200A-75 then check this website:-
http://3crwdr.googlepages.com/
da4eeaf.jpg Firmware Router 3Com 3CRWDR200A-75 V.3.0.1
Firmware Router 3Com 3CRWDR200A-75 V.3.1 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9b Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.9 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b7 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b6 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b4 Beta
Firmware Router 3Com 3CRWDR200A-75 V.2.8b Beta
_____
Regards
on Jun 29, 2008 | 3Com OfficeConnect Wireless Router
I cant save 3com router configuration
Try using internet explorer to change the settings, I was using chrome and it wouldn't commit any changes, but it worked with IE.
Nov 26, 2012 | 3Com OfficeConnect® (3CRWDR101A-75)...
I would Like To get a Firmware or driver of 3com router 3crwer101u-75.
swich on and of the small swich the phone wire check it call me if nothing works
407 729 7647 ask robert
Aug 12, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
My 3COM router doesn't support DDNS. Can I upgrade the firmware?
I dont know about the router as you havent provided full details, however there are multiple DDNS Clients that you can run on PC's and Servers, are you aware of these?
May 12, 2011 | 3Com OfficeConnect Wireless Router
We have a 3CRWDR101A-75 3com wifi router and its not upgrading the firmware, I downloaded the firmware from the site and then when I try to upgrade all I get is file verification failed... any thoughts...
The downloaded file is "corrupt", and thus it fails the "verification" process.
Download the firmware again, and compare the two files.
Or, use a different computer to download the firmware, and to do the firmware-update.
Apr 20, 2011 | 3Com OfficeConnect Remote 612 ADSL Router
3com Officeconnect VPN firewall Problem
Make sure the gateway and dns is set up correctly
Jun 08, 2009 | 3Com OfficeConnect VPN Upgrade for...
How does this product differ from the 3Com OfficeConnect Cable/DSL Secure Gateway?
The 3Com OfficeConnect Cable/DSL Secure Gateway includes all the security features provided by the 3Com OfficeConnect Cable/DSL Gateway, plus a full-function stateful packet inspection firewall for additional security. The 3Com OfficeConnect Cable/DSL Secure Gateway also provides VPN initiation/termination that supports the PPTP, IPSec, L2TP/IPSec, and VPN protocols.
Feb 16, 2006 | 3Com (3CR856-95-UK) Firewall
3Com OfficeConnect Remote 612 ADSL Router Logo
3,069 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Mike
Prashant M
Prashant M
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
