Question about 321studios DVD X Show for PC
I'm having problem installing theis product DVD X copy Platium
Problem: Cannot create file "C:\Windows\system32\IOSUBSYS\PCOUFFIN.VXD".
The system can not find the path specified.....
I'm running Windows Wista....Can you help..
Bought this software 4 or 5 yars ago
2 Suggested Answers
angelo_mlc
  • 1035 Answers
SOURCE: I have just upgraded to
Hi. Did you mean upgrade or downgrade? XP is older version than windows 7. Error you are getting means that the system cannot find the path specified. Are you installing the program using the the installer disk?
Posted on Oct 02, 2010
Hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you...
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
These 5 commands will delete the current, corrupt registry hives.
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
These 5 commands will copy the pristine, uncorrupted hives into your system.
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Advrcntr2.dll is missing
CLICK HERE TO DOWNLOAD
To install advrcntr2.dll, follow these instructions:
  • Open the zip-file you downloaded from DLL-files.com.
    • Extract the .dll-file to a location on your computer. We recommend you to unzip the file to the directory of the program that is requesting the file. If that doesn't work, you will have to extract the file to your system directory. By default, this is C:\Windows\System (Windows 95/98/Me), C:\WINNT\System32 (Windows NT/2000), or C:\Windows\System32 (Windows XP, Vista, 7).
    • Make sure overwrite any existing files (but make a backup copy of the original file).
    • Reboot your computer.
    • If the problem still occurs, try the following:
      • 1. Press Start and select Run.
      • 2. Type CMD and press Enter (or if you use Windows ME, type COMMAND).
      • 3. Type regsvr32 "filename".dll and press Enter.
Dec 01, 2010 | Microsoft Windows Vista Home Basic for PC
I loaded Check-it Fastmove on a laptop running windows XP. It will not start up and gives the following message: Could not start communication service. It worked fine on my old Desktop running windows XP.
I struggled with this same problem a few years back. I tried a couple of different compatibility modes for the fastmove.exe file and finally settled on Windows 98/Windows ME mode. When you right click on fastmove.exe and enable this mode in properties, you still aren't all the way there. When you try to run fastmove in this mode you will get another error message. Something about how it could not find a file called paralnk.vxd (actually the error message mispells the file name as paralink.vxd).
Well this file is only necessary for parallel port connections which I don't think anyone uses anymore (everyone should be using USB to sync). So I got to thinking that all the Fastmove program needed to see was a dummy file called "paralnk.vxd." And I was right. So this is what you need to do.
1. Find "fastmove.exe" in your program files, right click on it, click on properties, go to compatibility tab, enable "Windows 98/Windows ME" compatibility mode.
2. Go to your Windows\system32 folder and right click on some empty space. A dialogue box comes up. Mouse over "New" then click on "Text Document." After you have created the new text document, rename it to "paralink.vxd." You will get a warning message about changing the filetype from txt to vxd, but ignore it.
It doesn't matter that the new paralink.vxd is just a dummy text file. Fastmove doesnt use the file for anything. It just wants to see that it is there.
And that is how you get fastmove working on XP. It also works in Vista.
I sure wish they would update this program, but it got discontinued. Best sync program I ever used. I wish I knew who the actually developer was. I would contact them and see if they wanted to update it on an open source project.
Sep 19, 2010 | Smith Micro CheckIt FastMove...
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
When I insert a cd in my player I get this error oe 0028:c182b573
Method ONE Disable the SCSI1HLP.VxD using the Microsoft Configuration Utility:
  1. Restart your computer, press and hold down the CTRL key while Windows is starting, and then choose Safe Mode from the Startup menu.
  2. Click Start, click Run, and then type msconfig in the Open box.
  3. On the Static VxDs tab, click to clear the Scsi1hlp.vxd check box, click OK, and then follow the instructions to restart your computer.
Method Two loadTOCNode(2, 'resolution'); NOTE: By following the steps below, any device that uses the Scsi1hlp.vxd file may not function properly or you may not be able to restart your computer. Some SCSI devices and some ATAPI devices use this file. If you are not sure if your hardware uses this file, check with your hardware manufacturer before you proceed.
Rename the Scsi1hlp.vxd file in the Windows\System\Iosubsys folder:
  1. Restart your computer, press and hold down the CTRL key, and then choose Safe Mode from the Startup menu.
  2. Click Start, point to Find, and then click Files or Folders.
  3. In the Named box, type scsi1hlp.vxd, and then click Find Now.
  4. In the list of found files, right-click the Scsi1hlp.vxd file that is located in the Windows\System\Iosubsys folder, and then click Rename.
  5. Type scsi1hlp.old, press ENTER, and then restart your computer.
Apr 04, 2009 | Microsoft Windows 98 for PC
DVD X Copy Install Problem - Unable to find path
What you would need to do is go to www.driverguide.com and search for pcouffin.vxd and copy it to c:\windows\system32\iosybsys. Then it should install fine.
Jan 31, 2009 | Computers & Internet
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
321studios DVD X Show for PC Logo
160 people viewed this question
Top 321studios Computers & Internet Experts
Alun Cox
SHIVAJI YADAV
SHIVAJI YADAV
savageinjun
Are you a 321studios Computer and Internet Expert? Answer questions, earn points and help others
