Question about iLO LCT32HA36 Television
Tv will not turn on, has power and red led is lit
Ilo model lct27ha36, manufactured in July 06. Set has power, led indicator on front of set is lit red, but only blinks when power button is depressed on set or remote.
  • harryhorick Dec 14, 2008
    light blinks only once for each time power button is depressed, but blinks constantly if button is held down. I held it down for about a minute and it blinks at about 1 per second, and doesn't stop until power button is released.
  • 60 Answers
There is some trouble in your tv i mean the power suplay go in protect mode because something bad hapened in your tv like orizontal baleisge had trouble or othere causes you should go in one authorized service to fix that
Posted on Dec 14, 2008
  • 10,594 Answers
It is problem with Power Supply board. Tv is not getting power for its other circuits so unable to power up properly.
You can have power supply from Shop Jimmy on lower price.
Good luck.
    Genius:
  • 2,920 Answers
There are 4 capasiters inside the back of the tv you might look and see if any of them are popped. if not then the only other remedy would be a repairman. the diodes on the set are touchy and hard to pin point which ones are bad and which are good. the capasiters are in each of the 4 corners of the tv inside
  • iLO Master
  • 13,433 Answers
The blinking is a fault code, please count the blinks. this will definitely require repair but lets see if the blinking can tell us anything about the fault.
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
How do I set up universal remote for my Ilo TV model #DTV2784 and Sylvania DVD player model #DV220SLB. Got the separate VHS player to work, but not the DVD player. Was looking for Aux channel on TV f
Codes to check with ILO TV are: 0198 1070 1024 1023 . Keep in mind that.
If one code do not match with your TV, try an other code only after switch OFF the TV by its Main Power On/Off switch, and switch it back again.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Aug 13, 2012 | Televison & Video
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to jah2mil@hotmail.com if you required further assistance.
Aug 17, 2009 | iLO Televison & Video
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Oct 01, 2008 | Televison & Video
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Ilo lct27ha36
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Apr 01, 2008 | Televison & Video
Prog. indicator light
This is what one for all's web site says to do:
1. Turn on the device you want to set-up (ie: TV, DVD, etc).
2. On the remote control, press the device key for the device to be set-
up. For example, to set-up a TV, press the TV key; to set-up a DVD,
press the DVD key, etc.
3. Press the "SET" key and hold until the small light ("LED") on the
remote control blinks twice, then release.
4. Enter the Code for your device. If you've done it correctly, the "LED"
light will blink twice. (Note: 'Codes' are listed in the instruction booklet).
5. Press the "POWER" key and the device will turn off. It doesn't say the LED should stay lit after pressing TV here.
Try this and let me know at which step the remote programming breaks down.
Jan 30, 2008 | One For All URC-4330 Remote Control
iLO LCT32HA36 Television Logo
66 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
