Question about Kodak EasyShare C330 Digital Camera
Lens wont come out
I just used it and the lens came out and i went to go turn it on and now the lens wont even pop out and it says lens error 12...
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
SOURCE: Lens Error: 12
If the camera has been dropped or exposed to liquid, it must be sent to a repair store. Your warranty has been voided and you must pay for the repairs. The cost will be more than the purchase price.
Posted on Jan 01, 2008
  • 9 Answers
SOURCE: Lens error 12 appears on
It is very easy to fix. Just Be Very Careful when doing the following Repair.
You will need the Following a Size 0 Screw Driver, and a Small Eye Glass Flat Head Screw driver.
1. remove the 4 Screws holding the side panels. (Make sure you do not mix these screws with the ones on step 2) as these screws are shorter.
2. Remove the 6 Screws on the bottom of the camera
3. Now carefully pull apart from the bottom up. You will see 2 more screws on the left side but do not remove them.
4. Seperate the Front faceplate carefully around the Lens assembly.
5. while keeping the Camera with the lens Facing Strate Up, remove the Two Screws on the right side of the Lens, but keep caution not to move the camera while the screws are out of place.
6. remove the Cover to the Lens Gears.
7. Now this is very important!!!!, Take the Small Eyeglass Flat head Screw Driver and Pry the Gear To the Left, not the one by the motor. you do not have to take the gear off, however just enough to allow you to Move the Lens Assembly manualy.
8. Turn the Lower half of the Lens assembly carefully until the Lens is compleatly In and lens protector flaps Shut.
9. Put the Gear back on.
10. put the Gear Cover back on and Screw the Two screws back in. Make sure they are Firmly tightened
11. Put the Front Face Plate back on by putting on the top first, then closeing the bottom.
12. make sure the side pannel with the Wrist Strap is in Correctly before screwing it in.
13. Place the Side Pannels back on and Screw them in.
14. Screw the 6 Bottom Screws back in.
Now put the Battery Back in and test it out. This should fix the error you were having. i just perfomed this on my camera 15 min before i Wrote these instructions it worked! Step 15 get back to taking great shots!
jakthebomb
Posted on Apr 02, 2009
pbenke
  • 88 Answers
SOURCE: Today, I was using it. Turned it off for a whle,
Most probably the lens problem, it got stuck or it's damaged. Try to gently pull out the lens to see is it only got stuck or take it to service
Posted on Jun 24, 2009
t00nz
  • 4738 Answers
SOURCE: how can i fix a lens error on s610?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 14, 2009
  • 102366 Answers
SOURCE: m425-12 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
My camera is not working it wont turn on but the light flashes what could be wrong
It coud be either a battery probem, or the lens could be stuck. Here are two web blogs that deal with these problems, and describe things you can try to get the camera working:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Even though the blogs are titled for "dead cameras" and "lens errors", the solutions apply to your problem.
Good luck, and hope this helps.
Dec 09, 2010 | Cameras
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 29, 2009 | Nikon COOLPIX P90 Digital Camera
How can i fix a lens error on s610?
Jul 13, 2009 | Nikon COOLPIX S610 Digital Camera
Today, I was using it. Turned it off for a whle, went to ues it again & it wouldnt turn on, the power light was on & three beeps came out of my camera! It wont turn off until I take the battery...
Jun 23, 2009 | Samsung L100 Digital Camera
Lens error and blurry photos
If your images are blurry and the lens wont move smoothly it is very probable that some kind of force on the lens has damaged a gear, barrel or even dislodged an element internally. When the lens detects an obstruction in its movement the camera reports accordingly,"lens error". You should have the camera checked by a service centre, it will most likely need the lens replaced as they are not serviceable.
Apr 14, 2009 | Canon PowerShot A630 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Kodak EasyShare C643 Lens Error
Apr 22, 2008 | Kodak EasyShare C643 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
59 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
