Question about Crosley CEDC392JQ Electric Portable Dryer
Crosley dyer i post a comment on the old dyer page i guess that not haow you do it. i did what you said but the dyer light does not work so now what do i do thank you jesse
  • 641 Answers
Should be closed.
Posted on Aug 04, 2007
Ok got my 1995 ponti firebird to come alive again.
Hello Tim
You should really post followups as a COMMENT to the orignal post. I see you have made lots of new posts to chart your history of fixing the fault. If you do it as a COMMENT, the people helping you get a notification, and will continue to help and also be thrilled to hear that your problem is fixed. Fixya gets 7 million questions a year, so the chances of the right person seeing your reply as a new post are very slim.
Thanks for using Fixya. All your posts are on the links, you could copy and paste your good news to all the posts perhaps?
Fixya Moderator
Tim Dyer Fixya
May 23, 2016 | Cars & Trucks
Model 302 Desk Extreme static and crackling - other phones work well in the same plug-in. Mfr Dec 2003
13 years old , I would guess it is past time for an upgrade to a new phone .SORRY
Feb 11, 2016 | Crosley Lands Phones
Have a first alert et220 timer. After setting it and turning back to current time, pm light goes out and clock does not run. Manual switch works fine
Timer is not identified for certain. Expert does not have instruction manual and can only guess at cause of problem.
For example not all timers are rated for CFL or halogen bulbs.
Loose light bulb filament, or loose light bulb, or dirt in light bulb socket can cause problem, replace light bulb.
Conflicts in timer programming can cause problem with digital timer.
Read more options listed below:
1) Add a comment and describe timer appearance and if timer is programmable or has a rotary dial.
Describe what buttons appear on timer.
2) Take photo of timer and post on flickr and add comment with link to that photo.
3) Scan your timer instructions into file format. Post this file to Flickr and then add a comment with link to those instructions.
Sep 09, 2011 | First Alert 24 Hour Timers - 2 For The...
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
May 25, 2009 | Kenmore 63942 Dryer
Crosley Model CR79 (4 in 1) not working
FWIW, here's a link to Crosly online support. The only phone number I know of is 1-866-CROSLEY.
I suspect you might have better luck with a reliable local stereo/audio technician.
Sorry I couldn't offer more hopeful advice...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
No light on the control panel.
The new dryers need both hots(red & black) and the white plus ground to operate the control panel properly do you have a three prong or 4 on the dryer out let? try a new cord & plug before calling someone
Aug 29, 2008 | Whirlpool GGW9200L Gas Dryer
Sorry, here is the original post.
When you press power does the led light at all? That chassis has been plagued with bad flyback causing dead sets sometimes the led will flash 3 times slowly then go out. Other times it will make a soft short hiss. Does your set exhibit any of these signs?
May 12, 2008 | RCA P52926 52" Rear Projection Television
Jesse, does the door light come on? If not check the thermal fuse. You will have to open the top by pushing in on the two clips on each side. In back, on the right side of the heater you will see a thermostat and about 4 inches below the thermal fuse. Look at number 5 in the attachment. Makes sure to kill the power before going back there. You can either jump it out or ohm it out to make sure that is the problem. Part number for the fuse is LA1053.. back
Mar 11, 2007 | Crosley CEDC392JQ Electric Portable Dryer
Crosley CEDC392JQ Electric Portable Dryer Logo
76 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
