Question about Kenmore 62602 Electric Dryer
Tention pulley or so i think
I got a kenmore 70 series dryer well my belt brocck and slung i think the tenion pulley out need to know were i have to put it back at for it to work
    Genius:
  • 1,122 Answers
It goes in front of the motor,you'll see the slots in the cabinet under the motor,both side of the belt go under the pully and onto the motor pully-mike
Posted on Dec 18, 2008
Ngd7200
if you rapped the belt around the pulley and it's not tight enough then you popped the spring off of the pulley,you'll have to pull the drum again so you can see where the spring connects to the pulley,here's the sears site,put your model number in,click on cabinet parts and you'll see number 15 tention spring,this has to be connected to the pulley arm.http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NGD7200TW10/1268/0151200/W0712024/00002?blt=06&prst=&shdMod=
Nov 12, 2011 | Amana NGD7200TW Gas Dryer
How do I replace the dryer belt on a kenmore 70 series dryer
remove two phillips screws under lint screen trap door pop lid up... remove two corner screws usualy 5/16 nut driver lift upward and off to the right idler pulley bottom left pat attention to belt routing before taken off relace pulley change belt and repeat steps and reinstall
Jan 31, 2011 | Kenmore Dryers
I have a Kenmore 70 Series Dryer and the belt broke. I ahve since ordered the replacement belt, but am uncertain how to replace it. Is there somewhere I can view a diagram of my dryer so I know where the...
pulley fits into slots in bottom of dryer near motor pulley. idler pulley will be to the left of motor pulley looking at it from the front. loop belt thru idler and place around motor pulley.
Jun 26, 2010 | Dryers
How do i replace the belt on my model 70 series kenmore dryer
You need to remove the dryer casing so the drum is viewable. You need to release the tension on the tensioner pulley and slide the belt off the pulley, then you can slide the belt off the drum. Replacement is the same as removal. The tensioner pulley can many times be accessed through a compartment in the rear of the dryer.
Apr 26, 2010 | Kenmore 62602 Electric Dryer
How do you replace a broken belt on the Kenmore 80 series dryer?
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 20, 2009 | Kenmore Dryers
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
Cant figure out how the belt tensoner works to hold the belt tight i have a kenmore 70 series electric dryer
There are 2 slots underneath the motor pulley.
The flat part of the tensioner goues in these slots.
The roller wheel will then be on your left.
With the belt around the drum, run the belt under the wheel and through the tensioner, then over the motor pulley.
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 62602 Electric Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
