ok theres a pcv valve located between the carb and the valve cover. its screwed into the intake manifold. make sure it is hooked up. also check for any vacuume leaks. if you find any cracked hoses, replace them.
also for the guy whos sami sputters on turns. check the ground stud located above the battery on the firewall. if its loose or corroded clean it up and tighten it.check the ground strap coming from the distributor area between the engine and firewall. make sure its in good shape. alot of times the distributor o rings leak oil on the wiring and rot it out. thats easy to repair also. check your engine mounts by standing on one side of the hood and grabbing the engine and pulling it side to side. the mounts are known for wearing out. they are fairly easy to replce and cheap. about 20 a piece if not less.
any more questions check out this site.
www.
zuwharrie.com
heres a bonus feature
http://www.acksfaq.com/faqsearchresults-.php
