Hi, Gotta Sony DvD Rec RDR-HX720 , no prob rec but when i try to play back what i just rec , i cant cos it hasnt rec anything? Tried different sources to rec but same result. Please help
Comments:
Mar 17, 2007
- Hi, Thanks for advice but forgot to mention the problem with the dvd recording and nothing being recorded is not with any disc but the HDD
-   Same problem: message 'can't record', but it does record and playback on DVD, on HDD it only record (time is running), but there's no playback afterwards.
Maybe format HDD (but I have no remote, so I can't test this yet).-   M_Amsterdam
Nov 07, 2007
-   when i try to record i get message cant record picture on dvd and hdd but will play dvds and hdd .please help-   recordnow
You may try a different style DVD disc. Are you using (+), (-), or (RW) the DVD makes a difference.
http://pdf.crse.com/manuals/2636511113.p... Here is the manual for your product. Check pages 9 and 10. These pages tell you the type of DVD disc to use, and what speed they can be used.
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several...
(More)
After formatting the RDR-HX710 says 'Disc is dirty' and don't wanna copy. Brand new discs of several brands gave the same problem. Yet I don't have a solution.
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart...
(More)
I can connect my Sony KDL40V4000 tv to my Sony RDR HX710 DVD recorder using scart lead and scart socket to record Analogue TV. (Line 1 ON RECORDER) If I change scart sockets on the TV from scart one to scart two, the connection becomes "smartlink" but when I try ro record from Line 1 on the tv, the pictire is blank.
Any suggestions?
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with...
(More)
My Sony RDR-HX710 don't recognise DVD-RW formatted with Nero. I can use them on the PC but not with the Sony recorder that don't recognise them and so I can' format them. What must I do? I use mainly verbatim 4x DVD+RW but happens the same with all other brands... Carlos jcmat@aeiou.pt
