Samsung model HCN4727W rear projection is having convergance problems. When the perfect focus button is pushed, it can not auto complete. When I try to focus the colors manually, it is not able to correct them. I think it be would be a control board causing the problem since it just went out one day. What part and about how much would it cost?
  • 586 Answers
    There must be two IC STK'S which need to be replaced.The part number would be as
STK-392-**
You can see it by yourself and the price could be checked at
www.partstore.com
Thanks for using fixya.
Posted on Dec 14, 2008
Samsung HCN5529W 55in Rear Projection can't Perfect Focus
hello What you have is a convergence problem. There is 2 modules inside your set that aligns the colors to have the same geometry and superposed . It is a common problem in rear projection tvs ,
You don`t have to worry about your blue tube , i`m sure it is perfectly fine, it just needs to be aligned through the convergence circuit.
Most often the problem is with those convergence modules that are faulty and need to be replaced.
Hope this will help good luck
Dec 07, 2009 | Samsung HCN5529W 55" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Red will not focus but blue will ...perfect focus stops in middle
REPLACE THE 2 CONVERGE I.C.'S. PLEASE LET ME KNOW IF FIXED. THANKS.
Mar 15, 2009 | Samsung HCN4727W 47" Rear Projection...
Convergance
you need to have both convergence ics replaced STK392-040 (2).resistors 3.9 ohms they will be open.
Jul 27, 2008 | Samsung HCN4727W 47" Rear Projection...
I had the same problem with mine until I figured out it was from the auto self focus. Normally it should be done with a picture that remains constant or close to it, or else the focus gets screwed up. Go to menu and setup, then turn the self focus off. If you look on the remote and slide the lower portion down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button and then press the self focus button and wait until its finished.
Jan 21, 2008 | Samsung HC-P4752W 47" Rear Projection...
Prefect focus control
On the remote you have a door. Open it and you'll find the button focus on the right side the second from up to down. If not is in the menu, go in setup, convergence, auto, ok.
Jan 04, 2008 | Samsung HCN4226W 42" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Samsung HCN4727W
Replace convergence amp IC's = tech skill required.
Then activate auto focus...............T.
Let me know if you want step-by-step help....................
Nov 18, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
