I have a two year old Samsung 26" HDTV that has lost two lines of pixils towards the top. Where do I take it to get it fixed, it is no longer under warranty. What approximately will it cost? I live in Olympia, WA 98502. I bought it in Eastern Washington and do not plan on going to that town again.
I called the 1-800 number for Samsung and got the name of a repair man in Renton, WA. I will speak with him about the potential cost and if it is worth fixing or just let it continue to decline. I do not need your services and do not want to spend $9 to find out where the repair man was.
Thank you for your time.
Posted on Dec 15, 2008
NEED TO KNOW IS IT WORTH FIXING A CRACK SCREEN NO PICTURE COLOR LINES.
You have to take it into a shop and the cost will be more than a new set. You cannot buy a screen that big and install it yourself.
Feb 14, 2014 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Horizontal flickering lines in a samsung 32 LCD HDTV
Get the professional, although this won't be an expensive fix... You likely have one or more caps in the vertical circuit that are going bad... A cap acts like a battery in a circuit taking on voltage and releasing it at an even rate. When they go bad their ESR (equivilent series resistance) rises and the cap takes longer to reach it's op temp and work properly...
A tech with an ESR meter will easily find and repair this one...
no other issues only a minor problem..
Press the ‘menu’ button on the Remote Control
  • Select ‘INSTALLATION’
  • Select ‘CONNECTIONS’
  • Select HDMI 1, 2 or 3 depending on the input you have connected the PC
  • Select ‘PC’
    But if your product is still under warranty, better contact your dealer and get the issue fixed
  • Jan 23, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
    Purple verticle lines on flat screen Samsung TV
    How does the tv menue look. Does it cover the stripes or do the stripes affect the menue. if menu ok main board if menu affected bad panel. If under 1 years it is still under Samsung warr. Even if older than 1 year contact Samsung to see if they will cover repair.
    Aug 31, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
    Horizontal Lines on a LN-S3241D
    i'm sorry to say It's most likely broken. I think the LCD screen is going. Try calling up Samsung to see if they can fix it or repair it for cheap. Good Luck.
    Aug 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
    Goodman 42" HDMI TV 5 years old has thin lines on the screen
    Appears most probably to be a fault in the inbuilt power supply capacitors. Getting them changed once solved my problem. If you opt to change yourself then don't blame anyone if it renders your TV unusable!
    Jul 29, 2009 | Vizio VA26L 26 in. LCD HDTV
    Display lost brightness
    forthe cost of the unit vs. the cost of having it serviced , ive decided to work on it myself. I have it narrowed down to the flourescent backlight or the backlight power curcuit.
    Sep 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
    HD image has lost sharpness
    You will need to replace the convergance IC's if the colors are no longer lined up and they won't line up using the tv's controls. Also, if the crt lenses have a lot of dust on them removing that will help the sharpness and brightness of the picture. Don't use canned air. Get a crt lens cloth.
    Jul 07, 2008 | Akai PT5598HD 55" Rear Projection...
    SAMSUNG LCD TV horizontal lines
    causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
    Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
    Lcd tv picture problem
    My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
    Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
    Pixilated (purple) on top half of tv
    Not your bulb, prob with the display unit. Could be a driver or decoder IC...accordianman
    Sep 27, 2007 | Samsung DLP HL-P5663W 56" TV
    Televison & Video Logo
    41 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
