Question about Garmin eTrex Vista HCx Handheld GPS Receiver
Backlight issue with the Vista HCx
It would seem to me that I should not have to set the backlight level every time I turn on the unit.
Under Setup...Display, I have set the ''Backlight Timeout'' to 1 minute, and have tried to set the ''Backlight Level'' to 15%. It seems that every time I turn on the unit, the backlight is at 0%.
If I go back to the Display setup screen, the ''Backlight Level'' has reset to 0%.
I am using software version 2.80.
Any explaination or assistance would be appreciated.
Thanks,
Brian
I called Garmin. This is "As Designed", so we are stuck with this. Annoying, but all you have to do after turning the unit on is:
1) Press Lower Right button twice
2) Press Upper Right button once
Unit will now behave as you directed until you turn it off
Posted on Jan 06, 2009
SOURCE:
TCL LED LCD 55" - Backlight issues
Repair or replace the backlight.
Nov 24, 2013 | Televison & Video
VO37L HDTV10A backlight on, get sound, no picture
TV sets that have been exposed to significant surges can have multiple boards that are damaged. If the backlights are indeed firing, and you get no picture, you may have a problem with the T-Con board, assuming the main board is working properly. This is exactly why I steer people away from repairing sets that have been hit with large surges. In most cases it will be cheaper to buy new sets vs. repair them.
Jan 17, 2013 | Vizio VO37LHDTV10A 37 in. LCD TV
What causes the back light to quit working, until the pulling up the backlight level under the video menu
if its a Mitsubishi you might consider asking them---they keep an extensive database by model number of known issues and causes for them---might be a known issue.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
Lost its brightness and clarity
Hello
Check whether the backlights get full brightness as you increase the bright ness level. Set the set to least contrast level, and check whether the backlight is sorking well. If it is OK, then try to increase the contrast level [to at least 70% of the total]. If backlight level cannot be adjusted according to the contrast level the backlight inverter baord and backlight CCFL lamps need to be checked.
images of the backlight inverter board and CCFL lamps are attached here.
Feb 21, 2012 | Toshiba 42HP66 42 in. LCD Television
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Backlight
Hi Em,
You wanted to turn off permanently the backlighting on your IPod Nano? Your player uses that backlighting in order for users to see the display during poor lighting conditions.
If you really wanted to switch it off, you can access the backlighting settings on your player; Select Setting then go to Backlight Timer, Choose the option that suite your need
(Always On, Off, Turn off after a period of time between 2 and 20 seconds) or you can press and hold the Menu button down to toggle the backlight on your player to on or off.
May 05, 2008 | Apple iPod nano
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Garmin M5
Could it possibly be your backlight setting? I had a problem with my screen staying dark until i set the brightness level.
settings -> system -> backlight -> brightness -. then adjust your settings.
Aug 06, 2007 | Garmin iQue M5 GPS Receiver
Garmin eTrex Vista HCx Handheld GPS Receiver Logo
651 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
