Question about Zenith A50M84W 50" Rear Projection Television
Zenith rear projection a50m84w
The green and blue coloer lines in the convergence are curved. The convergence app works but will not line up what can I do to fix it.
    Genius:
  • 2,920 Answers
You need to change your convergence board
Posted on Dec 14, 2008
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Top of picture has distorted curve
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Double vision
If your picture looks 3D and you cant line up the colors your convergence ICs need to be replaced. Post your model number and I will post a link where you can get replacement ICs and get free tech support and instructions so you can do your own repair and save about 400.00
Apr 10, 2008 | Zenith A50M84W 50" Rear Projection...
Zenith 50" R56W36
maybe on your remote press menu and find converence and use the keys to move the red first over the green then move the blue over the yellow ..by standing back and just using the remote....should end up with white lines. and dont hit that button again once set. a tech should do this quickly and charge you minium.
Aug 16, 2007 | Zenith R56W36 56" Rear Projection...
Very poor resolution
Your best bet is to get a Zenith universal remote control.
Apr 14, 2007 | Zenith A50M84W 50" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
