Question about Kenmore Elite 45986 Front Load Washer
Door is Locked
The door on my front loader is locked and I cant get any of the controls to light up. I tried to unplug it and plug it back in. Im afraid if i force the door I will break it.
  • 92 Answers
You need to re-connect the power, leave for a few (20 seconds) then open the door. assuming you have emptied out all the water. the door have a timer fitted.
Posted on Dec 14, 2008
Light won't turn off of front loader model 796.4044
For a second i was thinking of a front end loader vehicle not a washer.
The light is on depending on the inputs into the main control board. The door lock could be causing this problem or the main control board could cause this type of problem.
Something a tech needs to analyse.
If you are mechanical at all try finding the door lock on repairclinic parts web site or appliance parts pro site. Many times there are fix it videos. Can't belive the switch would cost much. Alot less than the control board! Would eliminate one cause.
If you work on it unplug it!!
If you unplug and plug back in at least that should clear out the code and you can do a load. Not a permanent fix but better than not being able to do anything.
Hope this helps a little.
Minguy
Jan 26, 2017 | Washing Machines
Flashing light awo3361
Have you tried unplugging it for 30 mins. then plugging it back in?
Nov 02, 2012 | Whirlpool Washing Machines
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Mar 31, 2011 | Kenmore HE2 Plus Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
417 front loader washer - door doesn't register as closed, washer won't start all lights are lit except "door locked" of course I"ve tried to close door fully, unplugged, etc. but no go
The door lock/latch mechanism has failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Washing Machines
Control locked light come on and stay on, machine not running
take a good look and read on your control panel i don't remember which button you need to hold for 3 or 5 second to lock unlock control panel. it is also called child lock system.
May 21, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control locked light is on, machine is currently inoperable.
Push and hold the end of cycle button for 3 sec to lock or unlock control panel. here is the manual if you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606218.pdf
Good luck and please rate FixYa!
Apr 13, 2009 | Washing Machines
Maytag Neptune front load washer with FL code
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Jan 03, 2018 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Robert Rankin
