Question about HP LaserJet 2100 Printer
Had a paper jam it said open the back door to clear the jam
I did what it said i put the door back but now i get the door is open message
Try this.
Open up the printer and remove the cartridge.
next, lift up the metal flap (you shopuld see a note on the flap to this affect) to remove the paper "stuck" in the printer.
If there is a sheet of paper still lodged in the exit path, remove this by pulling it out from the back of the printer.
Insert the cartridge back into the printer remembering to put the metal flap back down into its original position first.
Turn off the printer using the on/off switch at the side of the printer.
Wait about 15 to 20 seconds and then turn it back on again. Printer will now start again and should resume printing again from the point where the paper got jamed.
Rod Salter.
Posted on Dec 16, 2008
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Keeps telling me to remove back tray as I have a paper jam. No paper jam. Message won't clear and won't let me put in new ink cartridges which it needs....printer is 2 months old....what gives?
You did not post a Make/Model but with many machines they will have a trap door/panel at the rear of the printer. If paper did not pickup from paper tray properly then it will show a jam message that can only be reset by opening the rear door/panel.
Jun 26, 2010 | Office Equipment & Supplies
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
E-04 Clear Paper Jam, no paper in printer
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 15, 2009 | Epson Stylus CX7800 Color Flatbed...
Jamming problem
try this
alternative :
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Carriage jam on HP Photosmart 3210 Printer
most likely the sensor on the paper path out of position, chech it out and put it back to where it have to be, good luck!
Dec 13, 2008 | HP Photosmart 3210 Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
HP LaserJet 2100 Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
