Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Blue and red double vision on HD projection tv
When you turn the tv on we have blue and red double vision
  • clmason64 Dec 19, 2008
    not only do we have double vision on words, we also have bands of fine interference lines at top 3rd and bottom of screen (red)
BMW Rider
  • 232 Answers
SOURCE: 53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Posted on Nov 27, 2007
ctf1800
  • 4402 Answers
SOURCE: 53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
  • 92 Answers
SOURCE: hitachi hd 57 inch rear projection tv.
You may be able to correct this problem with the convergence controls in the user menu. Hitachi also has on some projection sets a button called "magic focus" which is an automatic convergence control. If you can't seem to bring things back the way they should be you may have to get your convergence ICs replaced as well as some resistors in the convergence circuit. Unless you have above average soldering skills I'd suggest leaving that up to a technician.
Posted on Oct 07, 2008
  • 65 Answers
SOURCE: digital alignment on my Hitchi 46in projection tv
If the set cannot converge it self then the convergence ICs need to be replaced. Check local professional for prices
Posted on Apr 21, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi Projection TV 57F500A red looks double.
You need to replace both of the convergence IC's and any bad resistors around them that protect them from damaging the power supply.
This repair can usually be done in the home and takes about an hour; I have done hundreds of them and now is a slow time of year for TV shops; look around if you are not able to do this repair; you can buy the chips on Ebay for less than 15 dollars for a pair plus shipping.
This is a very common problem in projection sets.
If this has helped you give me a vote here as I do this for free. If you have questions or need help:
etower.766@netzero.net
Posted on Aug 23, 2009
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
KP-46WT510 Red lines and double vision
yes the convergence problem leaves a shadow of red or blue like an outline around the picture, sometimes part of the screen some times the entire screen.
Jun 26, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Phillips tv , double vision,
You have bad convergence IC's. Replace both the red and blue drive chips. They are easy to spot. They are mounted to large, finned heat sinks. The # on the chips starts with "STK-" and then there are numbers following. Both red and blue use the same part. There are 20 or so pins to unsolder\solder. These parts are available to the consumer from tritronicsinc.com. Good Luck!!
barneyluc
Oct 03, 2008 | RCA R52WH73 Projection Television
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Too much red + double vision viewing
This seems to be a convergence failure on your TV.
If you have hand basic soldering skills and a soldering iron, this might be something you can do.
Check this link for the parts you need.
Goo Luck.
Apr 02, 2008 | Samsung HCM5525W 55" Rear Projection...
KIT10 $29.50
Oct 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Double vision with blue outlines around objects on tv
you may need convergence amp replacement. this is a job to be done an experienced tv repair person ..but can usually be done for a few hundred buck$$
Sep 09, 2007 | Philips 50P8341 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
