My heater isnt working.. my pilot light is on but there is not heat going to home
    Genius:
  • 2,920 Answers
You might want to check the thermocoupler
Posted on Dec 14, 2008
Pilot light lit but not igniting to heat water
pilot lit on gas furnace, but the burners won't light (Home ...
answers.angieslist.com > Home > HVAC
Oct 26, 2013 - i have a gas furnace with a lit pilot, but the burners won't light. ... if the thermocouple does not sense the heat of the pilot it prevents the gas controller fromturning on the burners. ... clamped onto the outgoing hot water pipe, if huydronic system) that is telling the furnace it is too hot, whether or not that is true.
Nov 18, 2015 | Water Water Heaters
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
What would cause the pilot light on a gas heater to keep gooing out
Make sure you have a clean and strong pilot light. Take a rubber tube and blow the pilot head to make sure something didn't partially block your pilot when it was off reducing the heat to the thermocouple or thermopile.
Dec 31, 2012 | Desa International Heating & Cooling
Pilot light is off and it doesn't heat up at all. Worked fine until today.
try re lighting pilot if no check gas if ok replace pilot assembly or ignitor
Feb 26, 2011 | Saunacore Standard 5Kw 250 Cubic Ft Home...
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Pilot light keeps going out
probably need to clean the pilot orfice out. You will have to pull the entire burner assembly to get it out. Pull the tube going to the pilot light out and the orfice will be in the end closest to the pilot light. Once you get it out there might be a white fuzzy substance on it, clean it off, the hole in the orfice is very small, DO NOT make it any bigger, find something to push thru it like a single strand off a wire brush. After cleaning re assemble and re light, this should cure your pilot problems.
Mar 14, 2010 | Reliance & 30 Gal Mobile Home Water Heater...
My hot water isnt working and i need to know if the pilots go off on an electric water heater like gas if so how do i re lite the water heater
  1. if your hot water heater is electric there is no open flame or pilot light. They have electric heating coils,normally they are 220 volts.Follow the metal conduit up and back to the box check the breakers there will be two of them in for the hot water heater if it is 220 there will be only one fuse/breaker if it is 110. Check to see that they are on.
Dec 23, 2009 | Rheem Water Heaters
Poilot light is on but furnace will not turn on.
check diverter at pilot chech for lint could be gas valve re-light pilot
Oct 11, 2009 | RTO Home Heating Products 5.5HH240...
Vulcan freeloader hot water heater
Could be moisture in the gas supply line - get your gas fitter to purge the line at the meter.
Jul 08, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
