Question about NEC MultiSync LCD1512 Monitor
My wifes dog chewed the cable that is hard wired into the lcd .
Can it be replaced ? where do you obtain the correct parts, or can a new end be added? and where do you get the break ou for it?
    Sergeant:
    Champion:
  • 317 Answers
If it's the screw on type on both ends (I'm assuming it's the video cable), you can unscrew both ends and get another VGA cable (under 10 dollars each).
If not, you might want to consider keeping the dog away from cables, it was lucky not to chew on charged wires.
Posted on Dec 14, 2008
My dog chewed through the power cord. Can I replace this part without having to buy a whole new one? It's not mine someone was letting me borrow it.
You should be able to find a replacement at a hardware store. Take the plug end with you to get any assistance in determining the cord wire guage.
Apr 08, 2015 | Vacuums
Replacement speaker wire surround sound
philips part is going to be hard to find. Can you splice in a piece of regular speaker wire? Just make sure the wires don't touch each other or you can short out the amp.
Jul 19, 2013 | Philips Audio Players & Recorders
Our dog chewed the cable for the plug on our freezer ..repaired the cable and changed the plug but still not working
Your breaker tripped as he chewed it . Turn off the breaker then back on . It should be fine.
Feb 21, 2013 | Freezers
My dog chewed the plastic edges of my mobile
this is a hardware problem, get a new phone or get a new part to replace the chewd up part.
Dec 03, 2011 | Dual Electronics N99i Cellular Phone
I was whatching my daughters dog while she was away on business at my home. some how some way he managed to chew off the yellow connector plug for the speaker and chewed it up beyound use, as well as chew...
I was able to catch a glimpse of the back of this unit. I cannot tell by the picture but it is either a RJ11 connector or RJ45 Connector. RJ 11 is the connector on your landline phones and RJ45 connectors are used in computer networking applications. If you have either of these cable laying around you can verify which is which, after that if you do not want to buy the crimp tool for these connectors I would suggest sacrifice whichever cable it ends up being (RJ11 or RJ45) and splice your speaker wire to the two active leads, + and -. Good luck!
Jul 19, 2011 | Durabrand STS98RW Theater System
My dog ate part of my sunglass and i want to know where can i buy replacement parts?
Well this all depends on the parts. Usally with sunglasses it is hard to find the part on your own. Many parts are irreplacable or its not even worth replacing. Especially if your dog chewed on them then you should just get new glasses.
Jun 19, 2011 | Roberto Cavalli RC 369S Sunglasses
My dog ended up shewing the power supply cable. I bought a new one (original) and now It wont turn on. How can I fix it?
try a different wall socket and check the chewed cable and make sure it has no defects near the end where it plugs in. Double check the original cable as well and compare wattage, voltage, and resistance. Write down any model number and try to do an internet search on that number. If the first few hits are power cables, insure it is the one you ordered.
Mar 08, 2011 | Western Digital My Book Essential Edition...
Hello. A dog chewed the falt cable that connects the RX-NAVH80 to the FD-NH80. Is there a replacement cable available anywhere? If so, do you know what the cost might be> Thanks. Russ RussRossRR@aol.com
The company, Aiwa, is defunct. Parts & support, therefore, are zip. I used Gorilla tape to bind the cable ends together. It works as long as there is no movement to the cable. Best solution: time to shop for a new stereo.
Dec 02, 2009 | Aiwa NSX-AVH80 System
Direct tv cable
ok if its only the rf cable and the ac cord yes you can do it your self.you have one cable out from the sat reciver going to the dish. Find an area that the pooch didnot chew through cut off the bad part of the wire. find the wire that goes to the tv set. if its the coax disconnect from the reciver on both sides and go to the store and buy a new cable (unless you have coax wire and know how to put on f fittings) also while your there buy a small extenstion for the other cable you cut. also your gonna need a a female barrel connector as we;ll as an rg6 type rf fitting for the end you cut. have the guy at the store explain to ya how to put on a f fitting. If the ac cord was chewed buy a simple cheap extenstion cord too. Go home and first put back on the cable you took off the output of the sat reciver and the other end to your tv set. then put on the f fitting the guy explained to ya how to put on and then install the barrel connector then the short extention wire to the other side of the barrel connector then the other end of the rxtenstion cable to the sat output. Now if the power cord is chewed im surprised the pooch is not fryed!!!lol Simply cut off the bad part take the extention cord and cut of the end you dont need take off about 1 and a 1/2 inches of the insulation on bothe parts(reciver and cord) twist together and tape separatly or use wire nuts on them . then you are good to go. BUt one more little thing are you using video cables between the tv and the sat. reciver?? well why didnt you say so LOL simplyu pull out of both ends and go to rat shack or something like them and buy an inexpensive pair of cables and remeber yellow is always video red is alway right audio and white is left audio Hope this clears things up for ya.!!!!
Apr 02, 2006 | RCA DRD450RG DirecTV DTV Receiver
NEC MultiSync LCD1512 Monitor Logo
96 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
